Hi forum,
i am post processing from camworks to Mach 3 and need to sort an issue which re-occurs
Situation:
code operates all ok with exception of Z-height- I am assuming somewhere there is either a tool offset or reset of Z zero (stock surface)
i use a script to set tool zero (XY also set to start position) - on run and on cycle start the mill seems to reset z level.
anyone have a pointer on the gcode i should be look (g code newbie)
