586,067 active members*
5,287 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Generating code from solid
    Mar 2005
    39
    I'm trying to generate a code for a jetengine part.
    I had the part drawn up in a 3d program and exported as a STEP-file. Afterwards I imported it into BobCAD.
    I have a few questions on how to proceed. I know all the basics for the 2-1/2D machining, but never tried 3D.
    When I import the part I can't get the "zero-point" to the lower-center of the part. Normally you can press "P" but I can't select the lower center where the zero needs to go to.
    When I generate a toolpath, the path folows the curve of the part a a fixed distance (radius of the ballnose), however the mill needs to come down slowly cutting it's way towards the part.. any suggestions?
    regards,
    Adryan
    Jan 2006
    4396
    Quote Originally Posted by adryan View Post
    regards,
    Adryan
    Adryan,
    What Version of BCC are you using, V19, V20, or V21?
    Moving the Model.
    Select the Solid Model and Extract Line and Arcs.
    Then create a point at the center circle.
    Create a point x0 y0 z0
    Select everything except the two points
    Change Menu>Translate>Snap>No Copies>OK
    Select the center point of your circle then the one at X0 Y0 Z0
    The Model will origin at that point.
    Also Visit the BCC Webite and download the PDF Manual if your using V21.
    Visit these sites for help too
    http://cadcamtrainer.com/forums/index.php
    http://216.117.147.20/bobcadsupport/forums/
    http://www.bobcad.com/home.html
    Cheers
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2005
    39
    Hi Toby,
    I´m using V21.
    I´m trying the suggestions you made, keep you posted!
    rgds,
    Adryan
    Jan 2006
    4396
    The steps posted are a bit lengthy but will give the best Accuracy plus take the Axis Coordinate Guess work out of the task.
    Toby D.
    Schwarzwald
  1. Solid cam issue, filleted corners in g code
    By ozturbo in forum Solidworks
    Last Post: 09-19-2006, 11:15 PM
  2. inventor 3d solid to surfcam g code
    By villiersterrace in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 12:23 AM
  3. inventor 3d solid to surfcam g code
    By villiersterrace in forum Autodesk
    Last Post: 08-09-2006, 11:25 PM
  4. generating tool paths from solids
    By jderou in forum BobCad-Cam
    Last Post: 10-26-2005, 12:04 AM
  5. Solid model to CNC code quession
    By mikenelson in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 03:55 AM
