586,047 active members*
3,883 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Sheetcam g code problems
    May 2006
    238
    I am having problems with 2 computers that worked fine till yesterday and now wont generate plasma code. I thought it was the newest update but after doing clean installs to old version on both computers it worked for a few parts and then no code.Any ideas
    Thanks Dave
    May 2006
    238
    Re: Sheetcam g code problems
    Here is a log file of the problem. It seems to not see the license file. The license file seems fine on install
    2:01:44 PM: Application started
    2:01:44 PM: System language is English (U.S.) (en_US)
    2:01:44 PM: Currently selected language is System default language
    2:01:44 PM: Currently using English (U.S.) (en_US)
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\Autoload\Autoload.lua ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\BatchProcessing\Quickload.lua ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\BatchUpdate\BatchUpdate.lua ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\Calc\calculator.lua ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\DNC\DNC.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\dstv\DSTV.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\dxf\DXF.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\Excellon\Excellon.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\gcode\Gcode.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\hpgl\HPGL.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\Knife\Knife.dll ... Failed: Plugin is unlicensed
    2:01:45 PM: Plugin failed to initialise
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\laser\laser.dll ... Failed: Plugin is unlicensed
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\mach\Mach.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\RotaryPlasma\RotaryPlasma.dll ... Failed: Plugin is unlicensed
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\sim\Sim.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\svg\SVG.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\text\Text.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\USBCNC\USBCNC.dll ... OK
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\VCarve\VCarve.dll ... Failed: Plugin is unlicensed
    2:01:45 PM: Loading C:\Program Files (x86)\SheetCam TNG\plugins\Wire\Wire.dll ... Failed: Plugin is unlicensed
    2:01:46 PM: Connected to update server
    May 2006
    238
    Tried a different post and it seems to be working now
    May 2006
    238
    Turned out to be a license file problem
  1. SheetCam producing CRAZY code
    By mitchg in forum SheetCam
    Last Post: 12-20-2014, 01:44 AM
  2. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  3. SheetCam doesn't write G code
    By CORTE in forum SheetCam
    Last Post: 11-30-2013, 09:54 PM
  4. Sheetcam problems for newbie
    By Kentuckyfarmer in forum SheetCam
    Last Post: 03-31-2011, 02:07 AM
  5. dfx in Sheetcam to Mach 3 problems
    By Troy Gladson in forum SheetCam
    Last Post: 12-09-2010, 10:51 PM
