586,100 active members*
2,743 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Alarm in Bridgeport VMC 800 with Heidenhain TNC 370 CNC Control
Results 1 to 9 of 9
    Hi friends!
    The subject machine displays the following alarm immediately after boot up...
    "Z-Measuring system defective A"
    The specs of the machine Z-axis are as under:
    Z-axis drive: Siemens 6SN1118-0AA11-0AA0.
    Z-axis motor: Siemens 1FTS074-0AC71-1-Z.
    Z-axis encoder: ROD 350 500 P/R.
    Any help regarding the problem will be highly appreciated. Also we need the parameters list with description of TNC 370 control. Is there any way to get the z-axis referenced without encoder? if yes how to proceed?
    Waiting for any helpful response.
    Rana Ali.
    Dec 2011
    99
    Re: Alarm in Bridgeport VMC 800 with Heidenhain TNC 370 CNC Control
    A = Signal amplitude error
    B = Signal frequency error
    C = Error with distance-coded scale
    Possible error causes:
    - Encoder not connected
    - Cable damaged
    - Glass scale contaminated or damaged
    - Scanning head defective
    - Encoder monitoring system defective
    No axis can be used without the encoder.
    Hi sir
    1. How I identify encoder wire and signal A,B,C
    Can we measured by scope or meter at which connecter pin no .any description of connecter or wire colours
    2. What do you mean by encoder monitoring system defective which area(Hiedenhain Controller x3 connecter area )
    Please guide
    With best regard
    Rana Ali
    Dec 2011
    99
    Z-Measuring system defective A = Signal amplitude error on Z-axis
    Z-Measuring system defective B = Signal frequency error on Z-axis
    Z-Measuring system defective C = Error with distance-coded scale on Z-axis
    Amplitude error causes:
    - Cable damaged
    1: l1– (Yellow)
    2: 0 V (White)
    3: l2– (Red)
    4: internal shield (White/Brown)
    5: l0– (Pink)
    6: l1+ (Green)
    7: +5 V (Brown)
    8: l2+ (Blue)
    9: l0+ (Gray)
    Hi It
    Thanks for your help full response
    Please guide me that its encoder round connecter wire colours or x1,x2,------ at hiedenhaon controller side 9 pins female d sube connecter
    Dec 2011
    99
    Thanks again
    1) I change the machine parameter maesurong system monitoring all 000 or only z,
    than z axis proper move to reference but can't complete reference position. After that I push emergency after resetting alram z axis move other direction not in reference position side.
    And overtraval.I set again parameter.
    2)
    Dear sir I checked all connection found ok. Here I tell you that according to these manual I switch y to z connecters and also parameters .
    One time massage shift, after one time another alram display and measuring monitoring alram removed.
    ( Grass positioning error show z D)
    z axies suddenly drop when machine emergency stop release. And this alram display.
    How I can removed this alram
    Plz guide us
    Rana Ali
    Dec 2011
    99
    Replace encoder!
    Successor: ERN451 500, product ID: 376857-51
    I will try
  1. Bridgeport 412 with no power at the Heidenhain control
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2017, 01:26 PM
  2. Bridgeport Interact 412 W/ Heidenhain 151 control
    Last Post: 06-06-2017, 01:22 PM
  3. Replies: 60
    Last Post: 09-26-2015, 01:59 PM
  4. Bridgeport Interact 2 with Heidenhain TNC151 Control
    By lucylu in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2014, 10:36 PM
  5. Bridgeport Cnc R2C3 Parameters TNC 145 Heidenhain control
    By Trump in forum Bridgeport / Hardinge Mills
    Last Post: 07-07-2014, 09:12 PM
