586,489 active members*
2,574 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Need 1 simple CNC Part 7075 QTY 2 Bearing Block Measures 70mm X 100MM
    Aug 2006
    27
    I need 2 simple bearing holders machined from 7075 aluminum. Roller table bearing holder has a 47mm bearing journal and a 16mm through hole that need to be +or- .005 all other dimensions are not critical. Outside dimensions of block are 70mm x 100 mm x 27 mm thick. 47mm bearing journal has a groove cut in the center for a C clip to hold the bearing. Bearing journal is sized for a KBC 6204D bearing. See attached pdf. I can supply .IGS .STEP or .SLDPRT file formats. Both blocks will be identical see attached PDF for a sample model.
    RFQ: Roller table bearing holder QTY (2)
    Shane
    385-233-1090
    May 2015
    23
    Re: Need 1 simple CNC Part 7075 QTY 2 Bearing Block Measures 70mm X 100MM
    Pm Sent.
    Thanks, Matt Mittler
    Mittler Machine Works
    [email protected]
    Aug 2006
    27
    The RFQ is now Closed and has been awarded to P3d creations thanks for everyone quotes. I appreciate it.
  1. C12-100mm ER11M chuck holder with 12mm pillow block
    By varunalau in forum MetalWork Discussion
    Last Post: 04-16-2016, 01:36 PM
  2. Large 7075 aluminum block supplier
    By Texasbr in forum Want To Buy...Need help!
    Last Post: 03-14-2014, 01:37 AM
  3. Bearing in a block
    By ipburbank in forum Linear and Rotary Motion
    Last Post: 12-30-2012, 11:21 AM
  4. How to cut a bearing block ?
    By ringram2077 in forum MetalWork Discussion
    Last Post: 04-03-2008, 03:49 AM
  5. Help with bearing block
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 10:47 PM
