586,052 active members*
4,210 visitors online*
IndustryArena Forum > Other Machines > PCB milling > milling large openings in ground plane on one side of the board?
    Aug 2012
    279
    I am looking at a 2 sided FR4 board for RF (VHF) where one side is used for ground plane - the layout already exists(scanned artwork from an old magazine). The ground plane has about 30 holes that are from about 0.2 - 0.7 inches across and are odd shapes. I am just getting started with PCB milling and wondering how I can produce the large openings. I suppose I could mill the outlines (using an normal isolation V bit) and then manually peel off the unwanted copper foil. I could pull the drawing into a CAD program and generate gcode for milling them as pockets but wonder about the life of the end mill with all the surface area. Any other suggestions?
    Nov 2012
    154
    Re: milling large openings in ground plane on one side of the board?
    Although one can always use generic tools and plugins, PCB milling is typically done starting from a set of Gerber files exported from whatever CAD you designed your board in, using one of a number of specialized applications explicitly meant for PCB millings tasks. There are a number of these, and more or less all of them are capable of generating "rub-out" toolpaths for inter-track copper removal, in addition to the typical "isolation" toolpaths that only trace around the tracks. The most up-to-date and easy to use is probably FlatCam (FlatCAM: PCB Prototyping CAD/CAM), which can generate g-code for all work-phases - isolation / rub-out / drilling / outline cutout. For "rub-out" you simply select your copper Gerber and generate a "non-copper region", then select the resulting layer and generate a "paint area". It's all subject to various settings like margins, tool width etc of course - one generally does rub-out NOT with the V-tip engraving stylus used for the isolation pass (that would take basically forever), but with a standard cylindrical milling bit: 1mm/2mm/3mm, depending on how precise you want to be and how patient you are). What results is a toolpath like this, from which FlatCam can just export G-code to mill it directly:
    Attachment 364316
  1. Haas IOPCB Board - 175 Ground Fault
    By JimFraz in forum Haas Mills
    Last Post: 01-30-2014, 06:54 PM
  2. Replies: 2
    Last Post: 01-03-2012, 05:39 AM
  3. motor com and case ground pro board
    By Ed Williams in forum Hobbycnc (Products)
    Last Post: 03-27-2009, 04:21 AM
  4. PCB-Gcode - ground plane with 1 pass per path
    By Tester in forum PCB milling
    Last Post: 08-03-2008, 04:17 PM
  5. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
