586,043 active members*
3,687 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Table Height deviation = tool marks?
    Jul 2013
    608
    Hi guys, I have NEVER surfaced my spoil board. I used to cut MDF for the most part and some very thin acrylic,
    Recently I started experimenting with HDPE / Starboard with some thickness to it. On profile cuts that I use to separate the part I seem to be getting some tool marks and "poor" finishes.
    I noticed my spoil board is 0.04 or so higher towards the front than the back. This is consisten wit the markings. They are more preeminent when cutting left to right or parallel to the front edge.
    My question is, will such slight variation in height / slope can cause markings?
    here is a photo or some parts cut.
    Thank you.
    Nov 2013
    152
    Re: Table Height deviation = tool marks?
    Hi
    Yes it is possible that an uneven spoil board could be the cause but looking at the pieces you have cut it looks like chatter to me. Plus possibly cutting deep can show up spindle deviation. I.E. not being perpendicular to the table/job. Are you getting rid of the chips effectively ? Chopping chips can ( if it doesn`t melt ) cause cutter deflection and chatter especially if you also have alot of cutter stick out.
    Then there is work holding. If the stock material moves then that can also cause the effect you are seeing.
  1. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  2. How to eliminate heat marks from blade table on acrylic?
    By mirbearium in forum Community Club House
    Last Post: 07-05-2013, 04:55 PM
  3. Tool marks....GAH!
    By mlabruyere in forum DIY CNC Router Table Machines
    Last Post: 10-29-2010, 04:25 PM
  4. Tool marks
    By jfrandsen in forum MetalWork Discussion
    Last Post: 12-20-2009, 01:40 AM
  5. Setting up Z axis tool holder height above table
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 07-27-2007, 09:28 PM
