586,042 active members*
3,769 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Help with 120 conversion please
    Sep 2007
    Hello, I Am currently converting an emco 120 lathe.
    It has a Chinese cnc controller, simalar to fanuc system.
    I need to buy a stepper/driver combination for the lathe but I need some help choosing the best route.
    The axis force from the brochure states 10n force.
    Then ball screws are 5mm pitch, and the motor ball screw has a 2:1 ratio where the motor turns twice for every rev of the ball screw.
    The machine max rapid speed was 2000mm/min
    So I guess if I've calculated correctly, the motor would turn at 800 rpm at max rapid. I have no clue what the motor torque should be?
    So my question is should I buy nema 34 4.5nm closed loop stepper/driver?
    Or should I buy nema 34 8.7nm open loop steppers with dsp drivers?
    Or should I buy 4.5nm open loop steppers/dsp drives, and close the loop to my controller using an encoder?
    Or just simple and cheap 4.5nm open loop system?
    These options are all I can physically fit in the space available.
    Ideally I'd like to increase the rapids a little without compromising performance or reliability.
    Many thanks
    Lee
    Oct 2010
    670
    Re: Help with 120 conversion please
    Hey MonkySpunky,
    I don't have an exact answer for you but was curious. You stated that it's using a non Emco controller, how did you get the tool changer to work?
    I have a PC Turn 105 that I'd love to convert over to Tormach PathPilot control but the ATC is a huge issue.
    Thoughts...
    The Body Armor Dude - Andrew
  1. pdm 30 cnc conversion HELP!!
    By sledhead306 in forum Benchtop Machines
    Last Post: 12-11-2015, 05:22 PM
  2. CNC conversion
    By manofgresley in forum Want To Buy...Need help!
    Last Post: 03-25-2012, 07:30 PM
  3. My X2 Conversion So Far
    By sansbury in forum Benchtop Machines
    Last Post: 01-19-2009, 03:11 AM
  4. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
