586,103 active members*
3,355 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > What speeds are you getting with your EZ driver board?
    Nov 2005
    8
    I'm getting about 25 inches per minute with 5/16-18 screws, with 200 step/rev Nema 23 motors at 36 volts?
    Re: What speeds are you getting with your EZ driver board?
    What size motors?
    If I recall, when a lot of people were building Joes 2006 machine, they were getting about 100ipm with 1/2-10 single start acme, and 300oz motors. That's about 1000 rpm at the motor.
    I have
    - HobbyCNC Pro (same driver chips).
    - 1/4-20 drive screw
    - 36V unregulated linear power supply
    - 300oz in motors
    - 1/2 microstepping
    I can push it to 40ipm, but that's pretty much it. For milling, I will go to 38 ipm max, typically 30 - 35 (material dependent, of course)
    I only have a home-made DIY hobby machine, and for a 20 thread-per-inch drive screw, 38 ipm is pretty respectable.
    You can do the math to figure out the steps per second.
    BrianV
    WoodWorkerB
    HobbyCNC.com, WoodWorkerB.com
    Sep 2006
    245
    I have a HobbyCNC Pro and a 48V power supply. I forget what the microstepping is set to, but doubt that it would limit the max speed as long as the PC can keep up. I am using a 10 year old XP computer with a parallel port.
    My original router build had 10TPI ACME screws driven by 425oz motors. I could sometimes get 60ipm and would typically cut at 30-40ipm. Every once in a while it will stall and ruin the job.
    I switched to Ebay rolled ballscrews with 0.5cm threads, so effectively 5.08TPI. I could easily get over 100ipm and never felt the need to check the maximum speed. I usually cut at 60ipm and have never stalled the motors.
    Steve
  1. Help deciding which breakout board or driver board etc to use!
    By localbroadcast in forum Servo Motors / Drives
    Last Post: 06-09-2016, 09:25 PM
  2. Reduced operating speeds using pots on board??
    By Bullseye077 in forum Mini Lathe
    Last Post: 12-01-2013, 11:35 PM
  3. Replacing TB6560 driver board's driver chip. Is it possible?
    By Moodaguda in forum CNC Machine Related Electronics
    Last Post: 08-07-2013, 09:02 AM
  4. what driver board
    By smokingbob in forum Stepper Motors / Drives
    Last Post: 05-30-2009, 06:02 PM
  5. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
