Hello.
I have parts catcher in my Okuma LB15. Unfortunately I have not idea how to run it by G or M-Code. Have you some suggestions?
Best Regards
Hello.
Best Regards
hi
M76 retract
M77 advance.
I know that. M76, 75 are conect with turrets. I have manipulator to separate parts after cut.
Do you still use parts catcher on lb15?
If so, did you install or was it on machine already?
I might have Toellner quote me.
Is it worth it?
- Dkr
M75 & M76 at least for me is the advance/retract of the tailstock. You may have to get with a service rep. for most likely additional M codes (another set of advance/retract codes). Or if your into electronics, switch the tailstock over to the parts catcher if your not using the tailstock. That will be the "jerry-riggin" way.
From OSP5020L programming manual
M76 retract
M77 advance
M55 tailstock retract
M56 tailstock advance
It might depend on how your machine was configured when it was manufactured.
It may not have the software or hardware for a parts catcher.
Ah, Ok, I stand corrected.
okuma machines usually have up to 4 extra m code outputs. if your parts catcher was fitted later, it is probably using a pair of these. one for advance and one for retract (or grip/release?).
could be m88/m89 or around there, check your 5020 manual.
