586,112 active members*
3,220 visitors online*
    Feb 2010
    22
    Fanuc OM PMC EPROM Memory failed
    Hello,
    I have big Problems with the PMC memory of my OKK PCV40. It is a Fanuc OM controller with its own PMC M module, on which the second Eprom "OF2" is defective. When reading this Eprom revealed that he has no more data stored. Unfortunately, I do not have the EProm data - does anyone have this data for me? Or can I find somewhere in the documents (printed listings I have)?
    So there is 3500kg scrap, i can crying... :-(
    Thanks for any help!
    Aug 2009
    44
    Re: Fanuc OM PMC EPROM Memory failed
    If you find a working machine like yours and with the same controller OM, you can copy the two eproms. The PMC program listing should be in the documantation of your machine. What does the machine manufacture says?
    Aug 2018
    44
    one of my customer have the same machine
    please give me the exact reference wrinten on the eprom for check .
    if it's the same , i can make you an offer .
    regards
    Jul 2023
    13
    hello!...do you have the binary files of the master card A16B-1010-0210/16D of the Centrum 3000 punch press...they are OE1, OE2, OC1, and OC2...the executive software version is 0130-11?
  1. Fanuc 10TF Eprom Damaged
    By Yazmo in forum Fanuc
    Last Post: 07-28-2023, 01:07 AM
  2. Fanuc Eprom
    By MysticMonkey in forum Fanuc
    Last Post: 07-28-2023, 12:52 AM
  3. Fanuc 11M EPROM Failure.
    By Harmeet in forum Fanuc
    Last Post: 05-19-2013, 09:17 PM
  4. Fanuc Eprom
    By gabedrummin in forum Fanuc
    Last Post: 06-06-2009, 10:26 AM
  5. FNC-5 memory module failed on back-up
    By laser2500 in forum German
    Last Post: 01-23-2009, 05:00 AM
