586,032 active members*
2,764 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Cam/Cad software discussion. Fusion360 vs Vcarve vs XXX/Meshcam
    Jul 2011
    124
    Getting ready to get my very first cnc mill up and running. Pretty much zero experience on a mill. Maybe a few hours on a cnc router
    Playing around with fusion360 and it seems powerful but it's confusing as all hell.
    Is there any advantage to using a software like Vcarve pro? Or 123d/design or similar and Meshcam?
    I think vCarve is $600 and meshcam is $250 vs fusion is free.
    Curious as to what the pros/cons of each is?
    Re: Cam/Cad software discussion. Fusion360 vs Vcarve vs XXX/Meshcam
    If you're just making 2D cuts, V Carve Pro can be a lot easier, and a lot faster.
    MeshCAM has it's place, but I wouldn't recommend it for 2D work.
    Jun 2004
    6618
    I think Vcarve does some things better than Fusion. That said, those things are usually done on a router. For a mill, Fusion will be hands down a better software to learn. You do not need to eat the apple in one bite either. Take your time with it and watch lots of video tutorials. It is incredibly powerful software and getting stronger with each update monthly. The Cam side can in fact make your machine much more productive than many other choices. Thanks to the full blown HSM tool paths. I think learning Fusion will be time well spent.
    Lee
    Apr 2009
    5516
    Depends on what you're doing. If you work with .stl files, artwork stuff, then MeshCAM is probably best. If you're doing mainly pockets and profiles and/or sign work, then VCarve is best (the desktop version is only $350 or so.) For design and machining of parts, Fusion is probably best.
    Aug 2009
    294
    I agree with LeeWay and Louieatienza....decide first what you want to do with your machine, then pick the software that compliments your goals.
  1. VCarve Pro as a CAM software for Knifemaking
    By pearldiver in forum Vectric
    Last Post: 05-06-2012, 03:07 AM
  2. Vcarve or other software
    By wcarrothers1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-15-2006, 06:52 PM
  3. Free 3d Design software that works with meshcam!!
    By ShayArnett in forum Uncategorised CAM Discussion
    Last Post: 01-21-2006, 12:30 AM
  4. New - VCarve Wizard Software
    By Tony Mac in forum News Announcements
    Last Post: 01-07-2006, 01:37 PM
  5. Repost from CAD/CAM software discussion
    By fattuna in forum Waterjet General Topics
    Last Post: 08-05-2004, 05:01 PM
