Hello everybody,
An update has been posted. The library folders are here:
C:\ProgramData\madCAM AB\madCAM\6.0\Machines
Hello everybody,
hello all , with the new last 2 updates i always get a problem with simulation , for that i use the last update of the 10-2017 ( attached image showing the problem ) , and another problem is when i choose the stl model to do toolpath the box-region size will be exactly the same as the model , but if i rotate the working 180 degree using ( inedexed 4 axis ) the region-box will be bigger and i should go to the BOX REGION sellings and do changes manulay and put the size that should be .
thank you
jeries facouseh
