586,069 active members*
3,629 visitors online*
Thread: Tree VMC 750
    Jun 2017
    Tree VMC 750
    Hey all,
    So I have a Tree VMC 750 with Siemens PC2100 controller. In the middle of running a job yesterday I received and Alarm Message 39-22 "An error is reported by an x,y, or z axis drive." It is the Y axis. When I rebooted the alarm came up again as soon as I tried to move the y axis. I switched the x and y cables and the problem followed the cable. This morning I cut my wiring on the cable back and re-wired it (there was a shotty spot next to the plug, I thought it might be a bad connection in the cable) this made no result change. I was reading another thread on here that suggested possibly a bad ground. I re-grounded the machine and tried again. The machine booted and I was able to align axis and hand jog the table around. But when I ran the program it alarmed in the middle again. It seems that messing with the ground helped but I am still getting this alarm. Any ideas?
    Mar 2010
    45
    Re: Tree VMC 750
    sorry hadn't noticed your post previously and I haven't been on here in a bit... But I had similar problem that kept creeping back up.. The blocks that the cables connect to in the back of the machine have a way of working loose and causing these issues and/or going bad. They are near the bottom left of cabinet go in and re-tighten all wiring connections on those blocks for each axis, do em all while your there, with power off of course ; ) ... ! If that doesn't work you may have to replace one of them, few hundred bucks if I recall from ZPS, they have them. if that doesn't work get a hold of Bob @ ZPS he is extremely helpful and quick and knows these machines and keeps some parts for them.
    Best of luck!
  1. Replies: 8
    Last Post: 11-07-2014, 07:46 AM
  2. Tree 2 UVR-C
    By Russellcw in forum Tree
    Last Post: 01-12-2010, 05:20 AM
  3. tree 2uvr-c tree mill
    By willcofab in forum Tree
    Last Post: 06-11-2009, 07:40 PM
  4. Tree 325 value
    By bvweld in forum Tree
    Last Post: 12-13-2007, 05:09 PM
  5. Tree 310/315?
    By Provectus in forum Tree
    Last Post: 01-25-2007, 07:45 AM
