586,076 active members*
3,740 visitors online*
Results 1 to 6 of 6
    Jun 2017
    Maho MH600E transfer program
    Hello,
    I know a similar topic is already here. I have an older version of the Maho MH600E. I can not send the program to my machine.:tired:
    I tried various conneCNC and CademLite programs. When the program is uploaded, the D43 errors are erupted - invalid memory selected, D32- Parity error, D33- word length error, D42- Baudrate and recording is stuck on 21 lines.
    I have made a full Handshake cable about 5m long.
    I have a machine constant
    N771 C1
    N772 C3
    N773 C30
    N775 C1
    N776 C600
    N777 C600
    N796 C0
    I do not know the advice anymore
    Jul 2016
    6
    Re: Maho MH600E transfer program
    I have the same problem with my maho 600e, it stops the transfer after 6 lines..
    Jun 2017
    Problem solved. I gave a handshaking cable and it's ok.
    DNC software program and code editor for easy RS232 CNC file transfer 60 day free trial
    Jul 2016
    6
    I did not understand that ? You gave a handshake cable ?
    Can you maybe send the pinout from the cable you use ?
    Jun 2017
    I use cable Full Handshake, see link
    Http://www.smoregrava.net/Maho/mahomh500.htm
    Nov 2013
    13
    Quote Originally Posted by Pepa44 View Post
    Hello,
    N771 C1
    N772 C3
    N773 C30
    N775 C1
    N776 C600
    N777 C600
    N796 C0
    Hello,
    I have the same problem with my machine MH600E. Can I use these parameters you wrote here, as well as the cable sheme you posted via link? Which program should I use on my PC for sending G code to my machine?
    Regards..
  1. Maho MH600E - CNC432 Data transfer problems
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2021, 11:31 AM
  2. Maho MH600E/Philips 432 toolchanger
    By kovodilna in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-24-2019, 02:08 PM
  3. Maho MH600E Y axis Brake?
    By Davey Boy in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-15-2013, 09:33 PM
  4. Going for the Gold - Maho MH600E Conversion to Mach
    Last Post: 08-06-2012, 03:12 AM
  5. Maho MH600E Milling machine questions???
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2009, 07:51 PM
