586,036 active members*
3,532 visitors online*
IndustryArena Forum > Other Machines > PCB milling > 1/8" tool in 3mm ER11
    Would you expect a 1/8" tool in a 3mm ER11 chuck to be OK?
    With the chuck lightly tightened the tool is straight, but when fully tightened the tool tip wobbles. Am I tightening it too much or is it the size which is the problem?
    [Edit] Or is the chuck faulty?
    Dec 2008
    3109
    Re: 1/8" tool in 3mm ER11
    No....
    the shank is larger than designed for the collet bore,
    - unless the shank goes thru the entire collet bore, the outside collet taper will NOT match the holder's inner taper....this shows up as runout of the tool
    ER collets can only clamp on the range they are specified for,..... ideally, it is best to use the upper collet size, matched to the tool shank size
    ---- for a 1/8" shank, get a 1/8" ( or a 3.5mm ) collet..... it will run true when clean & clamped
    OK, thanks. At least the cure is simple if not desperately cheap!
  1. Looking for ER20 or ER11 adapter with 1/2" straight shank
    By Browellr in forum Want To Buy...Need help!
    Last Post: 01-26-2017, 01:46 AM
  2. modify post to add "next tool" variable after every tool change
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-22-2016, 08:56 PM
  3. 1/4" / 6MM router collet to ER11 adapter
    By sleziak in forum CNC Tooling
    Last Post: 03-21-2015, 01:06 AM
  4. Replies: 8
    Last Post: 02-01-2010, 04:45 PM
