586,069 active members*
3,629 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Does anyone actually make an add on ATC for bench top Mills? or even plans?
    I've searched to no end about this. I see that has Hoss build a few and a couple other people do the same. I'm looking for an off the shelf unit that someone can buy and install on a bench top? It's not that I can't fab one up I just don't want to if there is one out there already for sale. I don't care if it's home built by someone in their garage or a Chinese one sold on Alibaba. There's got to be something out there.
    The only thing I've run across is this one on Automationtechnologiesinc website, but if you look closely it actually has a lifting ring on it which means it weighs 10,000 lbs, OK maybe not 10,000 lbs but it is ridiculously heavy. There's got to be something out there. Any help?
    Apr 2015
    113
    Re: Does anyone actually make an add on ATC for bench top Mills? or even plans?
    Skyfire CNC sells their BT30 ATC spindle + carousal
    Luthier/Woodworker/Machinist in NS, Canada.
    Quote Originally Posted by jahnj0584 View Post
    I actually have a Skyfire vmc2 on order. Maybe when I get it I'll see if it will fit my Charter Oaks conversion. If it does that would be a way to go. Expensive upgrading the spindle though but maybe worth it.
    Jan 2012
    57
    Quote Originally Posted by Roadstercycle View Post
    Hi, Ive got an IH/Charter-Oak mill and was wondering if you were able to upgrade with the Skyfire kit?
  1. How to Make Wood Pellet Making Machine Plans?
    By cherryhong in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-14-2015, 01:43 AM
  2. Do expensive End Mills make a difference on a Tormach?
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 06-21-2013, 04:43 PM
  3. Mounting Bridgeport rams on other make mills
    By CNCISME in forum Bridgeport / Hardinge Mills
    Last Post: 08-07-2010, 10:08 PM
  4. Opinions needed on cnc bench top mills
    By M4RK_23 in forum Benchtop Machines
    Last Post: 01-10-2006, 05:48 AM
