586,094 active members*
4,206 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > EdgeCam post testing
    Mar 2010
    54
    Hi all
    Just wondering if there is a way to step though a code wizard post line by line to error trap and check functionality.
    Cheers
    scurr
    Oct 2003
    127
    Re: EdgeCam post testing
    have you used the code trace option?
    in code wizard, under "NC style,G-codes" there is a "debug" tab, in that check "generate code constructor trace" box and compile the generator. when you code a program this will label each instruction with the area of the generator that creates the code for that line.
    Mar 2010
    54
    Thanks that work a bunch. Now just have to work out the rest of the coding.
    Cheers
    Scurr
  1. Edgecam post
    By Doyle in forum EdgeCam
    Last Post: 12-23-2023, 07:32 PM
  2. Edgecam Dmu 50 post
    By erhanery in forum EdgeCam
    Last Post: 10-22-2013, 11:31 PM
  3. EDGECAM Post for YOU JI VTL
    By pr.vibin in forum Post Processor Files
    Last Post: 06-07-2011, 11:13 AM
  4. Replies: 0
    Last Post: 03-08-2011, 12:28 PM
