586,121 active members*
3,156 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Control Support DC to AC Servos
Results 1 to 8 of 8
    Apr 2008
    8
    Is it possible to replace the Glentek / AMP DC servos and drives with third party AC servos and still use the Fadal control?
    Mar 2016
    40
    Re: Fadal Control Support DC to AC Servos
    Fadal used AMC amps with Baldor motors also. If your motors jived with your amps and your amps jived with the axis controller cards then I guess you could do it. Glentek stuff getting hard to get? Why do you want to do that?
    Apr 2005
    1194
    You sure can BUT the DC motors are very long and have very high torque, tach, resolver. You can get AC and DC Fadal motors everywhere.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Quote Originally Posted by carbidecraters View Post
    for convert to ac motor Do i need change u15 and u18 eeproms on controler cards??
    Aug 2009
    1573
    Quote Originally Posted by Mhook View Post
    ...Hi Mhook,
    which type cards to you have? and machine...NUMBERS
    Quote Originally Posted by machinehop5 View Post
    ...Hi Mhook,
    hi
    my machine :
    fadal 4020 1996 dc motor
    and 1010-5a cards with
    1400-5A cpu
    Jan 2015
    417
    Yes you need AC eproms with the correct software if you have 1010-5 or-6
    Quote Originally Posted by rodney247 View Post
    thx
  1. How to control AC servos
    By floriptw in forum Servo Motors / Drives
    Last Post: 06-09-2017, 02:50 PM
  2. Replies: 3
    Last Post: 09-21-2014, 01:04 AM
  3. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  4. does fadal support polar mode?
    By brockmo in forum Fadal
    Last Post: 12-03-2008, 09:06 PM
