586,103 active members*
3,224 visitors online*
Results 1 to 18 of 18
    Jun 2017
    10
    Multicam cnc router 5000 series
    I have multicam can router 5000 series.
    the machine not finding home.the error (invertor not specified)
    In controllor cabinet ther invertor yakaswa not on.
    What is the issue and how can the solve the problum?
    I am from U.A.E.
    Can any one help me out.
    Jun 2010
    463
    Re: Multicam cnc router 5000 series
    Explain to me exactly what your machine is doing when it does to find home?
    Is it finding Z correctly
    Is it finding X and Y, where is the failure happing
    Jun 2017
    10
    Dear Sir,
    Glad to See your reply.
    I explain you what happened exactly.
    After finish the job machine stopped at home.
    When i gone to start next job machine not working.
    When i restart the machine but nothing happening.
    Machine asking for home.
    I press enter. than machine finding Z.
    After some minutes machine giving error of
    No Invertor Specified.
    On remote the rpm showing 1.
    When i go to controller cabinet.
    There are drives are on but
    The Yaksawa Invertor 315/V7 5.5 KW is not on.
    I checks the connections and check the Spindle drive breaker.
    The breaker is on. The next small breaker of 24v DC is off.
    I press the button for on.
    The Light blinks in invertor and than tripped.
    For futher i dont know what happened.
    I you will be easy i will send you the pictures.
    Thanks & Regards.
    Jun 2010
    463
    Which control board do you have in your machine, is it green in color or blue?
    Jun 2017
    10
    Sir i am send you the pictures where is the problem.
    The color of controller board is Blue M 2521.
    Attachment 366092Attachment 366092Attachment 366094Attachment 366096
    TheAttachment 366096
    In the Picture you can see the white color invertor is off.
    In the breaker there is current.
    In small dc breaker there in put terminal showing active but out not active.
    When i pressed it The white invertor comes active but suddenly its tripped.
    Hope you understand the situation.
    Thanks & Regards.
    Jun 2010
    463
    Check all of your connections in that circuit to make sure they are tight.
Name:	Screen Shot 2017-06-26 at 19.00.02.jpg
    Jun 2017
    10
    Dear Sir,
    I check all the connections they are tight.
    I find the RY3001 3001 3031 and 3030 have no 12v from main board.
    M3001 Not connected.
    Jun 2010
    463
    That lose connection at 3001, if it was just sitting there on the contact could have been shorting out the electrical enough to cause a lost of Modbus connection with the control board. Lets see what happens.
    Jun 2017
    10
    can you send me your num please i will call you.
    if you are easy.
    Jun 2017
    10
    can you explain what you say?
    I open the connections and than re connected and tight all the connection of M 3001 and cb 3001.
    Nothing happened.
    Mod bus not enabled. its showing on before going on finding home.
    When i start the machine the error is no invertor specified.
    If you give me your number.
    I will send you the videos on whats app.
    Jun 2010
    463
    Give me a call on Monday 5pm your time.
    678-548-1483
    Maurice
    Jun 2017
    10
    Dear Sir,
    I noticed on my controller board. M 2521.
    When i am enable the drives there are red color light on controller board CTS.
    when the drives are disable it was green.
    I call one technician he said there is a problem in controller board.
    what you think sir?
    Please guide me.
    The drives are ok.
    No error light in Drives.
    Jun 2010
    463
    When you enable your drives are the drives lights flashing rapidly, it they are flashing rapidly then the drives are ok. You indicated in a earlier post that the machine is telling you no inverter is specified.
    Seems like modbus isn't seeing your inverter
    You can check to see if modbus is detecting anything by going into the service menu
    push your shift key
    then your ? key
    hit your action key and hold until you see a S show up in the bottom right hand corner of the keypad
    Once that shows up
    hit your menu key
    scroll down to service selection
    you can scroll down and select test modbus, that will go thru and check to see what modbus device is found
    if nothing is found I would check to see if your modbus cable has a break and needs to be replaced or is it your ATCB board that has a problem
    Jun 2017
    10
    Dear Sir,
    I have multi cam cnc router 5000 series.
    There was a problem in Z servo motor. its giving noise.
    I replace the bearings of the motors. its become smooth.
    But after replacing the bearings now machine giving error
    Motor fault 4 z
    Count Blink 5
    I swap the motor with y.
    the error shifted to y axis.
    I am in Dubai.
    I call to multi-cam technical personnel. They ask me to replace the motor.
    Motor is ok i think the encoder have problem or its adjustment have some problem.
    Is there any solution in your mind.
    Or you have used motor in stock.
    Motor is MCG 3486-ME4698-F.
    Usman Azhar
    00971507668139
    Jun 2010
    463
    Afternoon Azhar.
    With a blink count 5, it is very likely that it is a mechanical issue. Encorder error are usually blink count 9.
    You still have a mechanical problem. This could be problem with the gearbox, I would swap the gearboxes, take one of the gearboxes from one the X sides and see if the error moves,
    If the error stays on the same servo motors then you will have to replace the motor, and I would send one in for repair.
    I do have 2 refurbished servo motor available later this week should you need one.
    Jun 2017
    10
    Dear Sir,
    Glad to see your reply. There is the issue in encoder. The glass inside the encoder is broken.
    The motor of z axis.
    There is no gear in z axis.
    Can you tell me where i can get the encoder.
    Or you have.
    Also please give me the price of motor which you have and how long its take time from usa to uae.
    Jun 2010
    463
    I forgot all about that the servo motor was the Z-axis and not the Y, my apologies.
    As for the encoder, send me a pic of the numbers on the encoder, my servo rebuilder will have these instock or can direct me where to order and I can forward that info to you.
    Pricing for the servo is 675.00 USD plus shipping, and shipping cost is dependent on how quick you would like it shipped.
    Good day,
    I am experiencing an encoder fault. The display shows Servo fault and the servo is blinking 9 times.
    What would you advise as the best course of action?
  1. Help Needed: Multicam 5000 Series
    By AversaS in forum Multicam Machines
    Last Post: 02-04-2016, 02:52 AM
  2. Servo Drive - MULTICAM 5000 Series.
    By Routerfiend in forum Servo Motors / Drives
    Last Post: 01-22-2014, 09:55 AM
  3. Multicam 5000 Series - Fail to initialize
    By frans in forum Multicam Machines
    Last Post: 07-22-2013, 06:12 PM
  4. Multicam 3000 Series vs AXYZ 5000 Series
    By adamfilip in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:54 AM
  5. NEED HELP - MULTICAM 5000 SERIES
    By loyedp in forum Commercial CNC Wood Routers
    Last Post: 09-21-2010, 04:08 PM
