586,075 active members*
3,798 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > New Mini Mill landed safe and sound
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Jun 2004
    6618
    Re: New Mini Mill landed safe and sound
    Hey guys. I have too many products now that we make and need to start using offsets higher than the G54 through G59.
    To use the offsets in Fusion 360, I add a number in the setup sheet that corresponds to an offset. G54 is 0 or 1, G55 is 2, G57 is 4, etc.
    Are the next number G54 P1, G54 P2 etc?
    If so, how do I implement them in Fusion?
    Lee
  2. #42
    Nov 2006
    490
    The Haas post should automatically jump into the G154 offsets when you specify a value higher than 6. So if you call it offset "7" in Fusion, it should output a G154 P1, etc
  3. #43
    Jun 2003
    1365
    What Ydna said, G154P1 G154 P2, etc. You can also use G110, G111, etc. Your post processor should be set up to handle it one of these ways.
  4. #44
    Jun 2004
    6618
    Excellent.
    Thanks, Guys.
    Lee
  5. #45
    Dec 2017
    8
    Quote Originally Posted by LeeWay View Post
    Excellent.
    Thanks, Guys.
    Did she come in early or right on time?
  6. #46
    Nov 2012
    145
    Quote Originally Posted by Ydna View Post
    Well that could explain it I've been scratching my head! With Fusion I plug in 54 for a offset but the new gen generator puts it as 154, so I take it I just enter 1 for 54. The other thing is it puts the feed rate at 650 and the TM1p dosen't run till it is lowered. I did change it in the post generator line 38 I belive, I'll have to check I might have the HSM turned off.
  7. #47
    Jun 2004
    6618
    Quote Originally Posted by Bubba73 View Post
    Perfect timing actually.
    And setting a 7 in Setup in Fusion 360 does set G154 P1 in the Gcode as mentioned.
    Lee
Page 3 of 3 123
  1. My SH-350 has landed !!!
    By itmaxx in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2015, 10:58 PM
  2. Super Mini Mill 2 vs Mini Mill Tool Tracking
    By Terry G in forum Haas Mills
    Last Post: 05-25-2014, 06:55 AM
  3. Is it safe to Face mill 0.9" thick Al
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 05-19-2009, 03:17 AM
