586,096 active members*
3,921 visitors online*
Results 1 to 15 of 15
    Jun 2017
    3
    CNC 3040 Parallel port pinout
    Hi everyone,
    I bought a used 3040T cnc machine with parallel port.
    Now my goal is to control it via USB over a Arduino Nano or Duo with GRBL
    PC -> Arduino with GRBL -> Control Box
    Know anyone the pinout of the parallel port that I can connect X Step, Direction and everything?
    The control box is the black one.
    Mar 2007
    2083
    Re: CNC 3040 Parallel port pinout
    As the various suppliers supply contolboxes with different electronic boards / modules depending on the stepper motors and spindle motor fitted.
    more information will be needed to make it possible for others to help
    for example
    this is one version of a control box for machines with a low power DC spindle motor
    found on the net
    Attachment 366116
    Attachment 366114
    stepper drive schematic pdf
Name:	YOOCNC NT65-3X  stepper_controller_schematic.pdf
    spindle control schematic pdf
Name:	psu_and_spindle_schematic  for YOOCNC NT65-3X.pdf
    printer port
    Attachment 366122
    you will need the manual for your control box to know the exact function of each pin
    John
    Jun 2017
    3
    I got the control box with the letters "T-D"
    May 2017
    8
    Open the box and check the model of the control box. If it is JP-3163B ver 3.9, here are the pinouts
    JP-3163B ver. 3.9
    Pin 1: Spindle on/off Relay 1(active low)
    Pin 2: X Axis Step (active low)
    Pin 3: X Axis Dir (active low)
    Pin 4: Y Axis Step (active low)
    Pin 5: Y Axis Dir (active low)
    Pin 6: Z Axis Step (active low)
    Pin 7: Z Axis Dir (active low)
    Pin 8: A Axis Step (active low)
    Pin 9: A Axis Dir (active low)
    Pin 10:Estop (active low)
    Pin 11: X Axis Limit Switch (active high) = when NC switch(es) open
    Pin 12: Y Axis Limit Switch (active high)
    Pin 13: Z Axis Limit Switch (active high)
    Pin 14: Buffer Chips “Enable” controlled by computer if Jumper 3 is set to 1-2 position
    Pin 15: Probe (active low)
    Pin 16: Is supposed to turn Relay 2 on/off but is currently not connected in board.
    Pin 17: PWM 0-10V for VFD Spindle AN1 (if jumper 4 is in default 1-2 position) active low
    Pin 18: Gnd
    Pin 19: Gnd
    Pin 20: Gnd
    Pin 21: Gnd
    Pin 22: Gnd
    Pin 23: Gnd
    Pin 24: Gnd
    Pin 25: Gnd or NC
    Sep 2017
    20
    Quote Originally Posted by reuel View Post
    JP-3163B ver. 3.9
    Pin 18: Gnd
    Pin 19: Gnd
    Pin 20: Gnd
    Pin 21: Gnd
    Pin 22: Gnd
    Pin 23: Gnd
    Pin 24: Gnd
    Pin 25: Gnd or NC
    Hello, I was wondering if the pin out would be universal for most of the controllers? I was the prt-e750 and connot get the spindle to move through mach3 . In motor outputs under spindle, what should step pin# be set as? as well as Dir pin#.
    regards,
    Josh
    May 2017
    8
    Quote Originally Posted by JoshG502 View Post
    regards,
    Josh
    NO it is NOT universal - that's why you must open the lid of the control box and find out the model number of your BOB (breakout board) and get the manual for that board.
    Or else buy a famous control board from Gecko.
    Sep 2017
    20
    Great, thanks for the reply! I have the bob number but still curious how the pins correlate with the step and dir. which is which. Thanks
    Mar 2007
    2083
    a quick web search for 3040 T-D didn't find your manual
    for now you can try the pin out in this manual
Name:	3020-3040 cnc router GUIDE.pdf
    John
    Mar 2007
    2083
    in answer to another thread I traced part of the circuit of the TX14175 BOB
Name:	partial TX14175 circuit.jpg
    mach 3 or what ever control software you use must send the PWM signal to Pin 1
    pin 1 is connected to 2 buffers that are part of a 74HC245 IC ( the 74HC245 is an octal buffer)
    one buffer output goes to one pin of a 2 pin connector ( next to the B axis 4 pin connector )
    the output of the second buffer drives the opto-isolator at the input of the PWM to analoge converter
    that produces the analogue DC control for your spindle motors control board
    the enable signal needs to go to pin 14
    which is connected to 3 of the 74HC245 buffers
    the output of one buffer drives the X and Y enable connectors
    the second buffer output drives the Z , A and B enable connectors
    the third buffer output goes to the second of the pins on the 2 pin connector
    john
    PS
    using the information from the above diagram this should be printerport connections
Name:	TX14175 printer port connections.jpg
    PPS
    photo showing TX14175 PCB track suppling 10V DC to input opto-isolators
    Attachment 373226
    input details
Name:	TX14175 bob location of input circuit on PCB.jpg
    Attached Thumbnails Attached Thumbnails TX14175 bob location of input circuit on PCB.jpg
  1. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  2. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  3. arduino parallel port hack for Chinese 3040
    By RunForrestRun in forum USB, RS232, PARALLEL etc
    Last Post: 05-07-2015, 05:59 PM
  4. no new computers have parallel?? experience on adding parallel port yourself?
    By teglberg in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 07:18 PM
  5. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
