I'm running kmotioncnc and can't get the interpreter to omit a G91.
Example G91 G10 L2 P2 X0 Y0.1
Would the answer be changing something in the
Tool setup screen -> tool/setup files-> setup file?
Hi dirtdigger257,
What do you mean "omit"? Ignore?
Please put more effort into your question.
Regards
TK
http://dynomotion.com
[QUOTE=TomKerekes;2062730]Hi dirtdigger257,
What do you mean "omit]
I mean it ignores it ,it should work in with G90 Or G91
Mactec54
G90 works better for any type of movement you want to do,
It doesn't work better for incremental moves
if you forget to cancel the G91 you will crash
This was just an example I know how to keep track of my modal codes
Try writing a 4 axis gear cutting program without using G91 The program would be way longer
Mactec54
I think you are using the wrong G code
G10 is used to PUT a figure into that field..... not ADD to an existing value
- you need to do a interrogation, & a calculation before you place the value into the work offset
ie
#1 = #5300 + 0.1 ( note #5300 is NOT the correct variable for the value in G55 Y area)
G10 I2 P2 Y[#1 ] EOB
G55 EOB
try using the global shift (00) area to adjust the origin
also lookup G52/G92 usage, if it is what you may be needing
