586,060 active members*
4,090 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > What material should I use to build a 450nm optical protective box?
    Dec 2016
    Question What material should I use to build a 450nm optical protective box?
    Hello there!
    Im building a laser graving machine from a former 3D printer, and have decided to buy this head to start my quest.
    The problem Im having now is that the machine will be in a rather busy place, where lots of people walk by all the time. So, a simple pair of protective gogles wont do the trick, as I wont be the only one needing protection.
    Is there a kind of acrylic protective glass I can build a box from? I cant find it in any DIY forums. Is it really necessary to have such protection when using a 500mW laser?
    Thanks in advance for any answers.
    Best regards,
    Afonso Urbano
    Re: What material should I use to build a 450nm optical protective box?
    Hi there,
    It's very necessary to have protection for this range of laser gun.
    Based on the wavelength of laser light a 500mW produces, you need about 106 meters clearance distance from the point of light to avoid any eye hazard.
    You can check this chart (http://www.lasersafetyfacts.com/reso...or-LSF-v02.png)
    Stay safe and keep others safe too.
    I hope my response isn't too late by the way.
    Thanks.
    Oct 2008
    16
    Not cheap... But yes... There are a few materials for that.
    Here is a good start : https://www.lasersafetyindustries.co...ers_s/1356.htm
    Jan 2009
    334
    Quote Originally Posted by afonsurbano View Post
    Hello there!
    Best regards,
    Afonso Urbano
    Try this: https://jtechphotonics.com/?product=...aser-shielding
    You may also be able to find larger sheets.
    Hope this helps,
    Iron-Man
  1. Looking for help to build a syllabus & course material
    By i-make-robots in forum Education - Teachers and Students Hangout
    Last Post: 06-17-2017, 06:03 PM
  2. General Info about uses/limitations of 2500mw 450nm blue laser module
    By myte in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-09-2017, 12:17 AM
  3. Material question on build
    By KajunKrawler in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-04-2012, 12:44 AM
  4. Material for Build
    By Liander in forum DIY CNC Router Table Machines
    Last Post: 01-04-2010, 05:03 PM
  5. NEW BUILD: PVC as a build material
    By Smiler in forum DIY CNC Router Table Machines
    Last Post: 11-13-2009, 11:57 PM
