Hi Guys
I have had mach3 for about 5 years or so. I had a computer that stopped working I was using windows xp so I decided to run windows 10 on a new computer. the new computer had to have a parallel port installed on it. I loaded mach 3 onto the new computer. I then had the mach3 file ported from my old hard drive to the new computer and copied all the files to the new computer mach 3 file. All my files and setting are now visible including backlash etc.
I start mach 3 turn my computer on load the mach3 and the machine will not move nor will it register the axis toggles. I stuck at this point. I checked device manager to see if the port was installed correctly and it appears to be(no red or yellow markings showing)
Any suggestions.
