586,121 active members*
3,509 visitors online*
    Jun 2017
    Issue with Mach3 and USS
    Hi all,
    Got my CNC up and running beautifully on my old computer but now I have a new Windows 10 machine with a USS smooth stepper. The ports and pins and everything I believe are configured correctly and I just got it calibrated and everything. Only issue is Mach3 keeps tripping the external reset button. First I thought it was my cheapy switch going out so I shorted that and it still trips reset after about 30 second of machining. I don't know if my separate spindle circuit is to blame or not. It seems to be more sensitive to reset trips the higher I run the spindle speed, but that could just be me.
    Any thoughts or suggestions? I had to move my USS away from the rest of my box due to interference. I am running a Gecko g540 controller along with its own power supply and another variable voltage supply for the spindle itself.
    Keith
    Re: Issue with Mach3 and USS
    I know this is an old thread, but I was able to fix a similar issue by placing a large ferrite core right where the DB25 goes into the computer
  1. alphacam to mach3 issue
    By edz_86 in forum Alphacam
    Last Post: 04-25-2017, 09:48 PM
  2. More of a Mach3 issue...
    By CROSSHATCH in forum Novakon
    Last Post: 06-18-2016, 01:28 AM
  3. Mach3 issue
    By Andrew2111111 in forum Machines running Mach Software
    Last Post: 02-10-2016, 10:41 AM
  4. Mach3 G28.1 issue...
    By davek0974 in forum Mach Software (ArtSoft software)
    Last Post: 04-14-2014, 06:44 PM
  5. Mach3 Backlash Issue
    By strohkirchw in forum Taig Mills / Lathes
    Last Post: 12-08-2010, 09:35 PM
