586,065 active members*
4,546 visitors online*
IndustryArena Forum > CAD Software > Autodesk > .DXF files open as .TXT
    Dec 2011
    7
    The last hand full of times I have tried to open .dxf files from this site, they load to my computer as .txt files. Is it because they are being drawn in a newer version of AutoCad? I have 2005, and I know when my co-worker tries to give me 2016 files, they don't work.Do I just need to update?
    Re: .DXF files open as .TXT
    Most .dxf files are just text files. If they are being saved with a .txt extension, then it's the way you are saving them. If you just rename the extension to .dxf, then they should open fine in AutoCAD, unless they are saved as .dxf version newer than 2005. I'm running ACA 2018, and there are .dxf versions 2007, 2010, 2013, and 2018. You won't be able to open those.
    Jun 2017
    32
    Yep - mod is correct. Check your default 'save as' or 'do this with file type X' settings if not getting prompted. If nothing works and you're hobbiest or small business under 100k in sales - might want to check out Fusion 360. Pretty nice, not perfect but it is current and price ($0 if meet criteria) is hard to beat.
  1. Unable to open AI files at AutoLaser
    By Frankie0808 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2016, 08:25 AM
  2. i open files to mach3 but
    By levon18lopez in forum Engraving Machines
    Last Post: 08-04-2013, 07:10 PM
  3. Want to open CatiaV5 R17 files into solidworks2010
    By hikid123 in forum Solidworks
    Last Post: 10-03-2010, 08:03 PM
  4. Open source Eagle pcb files
    By TinkerDJ in forum Open Source Controller Boards
    Last Post: 05-02-2006, 08:28 AM
