586,071 active members*
3,987 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > File size limit for RD6442S control system?
    Jun 2017
    19
    Hello everyone. I am brand new to the group and recently purchased a 60w Unich 1318 cnc laser. I am having a few problems that I can't seem to figure out.
    The first problem is that the lighter areas of photos are very faint regardless of the medium. I have tried different power levels and speeds, even lightening up the photo in both corel and photograv, but nothing helps.
    What I've tried so far is speeds between 200mm-300mm sec and power levels from 17-26% min with max set the same. I was able to successfully engrave these files on a different laser that of course had a different control card and software.
    The second issue is with large files. The laser bed is 51"x 71" yet I can't engrave a 24"x48" photo. Is there a file size limitation with the RD controllers?
    As you may know, tech support is not much help, any advice you can provide to help get this machine working properly will be greatly appreciated. Thanks in advance!
    Jun 2017
    19
    Re: File size limit for RD6442S control system?
    Turns out there is a file size limit. My file was 102mb I had to make it smaller and it worked out
  1. Windows x64 text file splitter that goes by lines, not file size?
    By Galane in forum Uncategorised CAM Discussion
    Last Post: 04-06-2015, 12:26 AM
  2. Factors that limit cutting bed size
    By curriergroh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2011, 10:47 PM
  3. ez trak program size limit?
    By Mikael! in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2011, 05:50 PM
  4. File size limit??? Dripfeed??
    By jsatter in forum Centroid CNC Control Products
    Last Post: 01-31-2007, 06:22 PM
  5. program size limit
    By stevieboy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-17-2006, 08:23 PM
