586,052 active members*
3,992 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > fadal slide hold turning on
    Feb 2007
    I have a 22-16 fadal with 88hs control and the slide hold keeps activating on its own during the run cycle. any ideas?
    matt
    Jul 2005
    100
    Do you have a door interlock problem?
    900
    If it is the "EXT HOLD" message that is coming up, then you door interlock switch ing breaking contact. Perhaps the doors have vibrated open some or are mis-aligned. If the missage is "SLide HOLD" then perhaps you have a shorting wire of bad hold switch.
    Neal
    Feb 2007
    I don't have the door interlock connected. It has run for about 6 months like this without any issues. And unfortunatly I dont get an error message of any kind the machine just goes into slide hold. spindle stays running. All i do is hit START and it continues as normal. ?????
    thanks for the replies.
  1. How do you get a hold of one cnc?
    By turboboy in forum OneCNC
    Last Post: 01-03-2007, 01:50 PM
  2. Replies: 4
    Last Post: 03-02-2006, 04:46 AM
  3. What should Feed Hold actually be??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 01-22-2006, 07:04 PM
  4. How to hold
    By MIKEB in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-05-2005, 02:50 AM
  5. What do you use to hold your work down?
    By cncadmin in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2005, 04:27 PM
