586,271 active members*
3,461 visitors online*
Results 1 to 2 of 2
    Sep 2016
    10
    Deleteing stuff
    Say you have a drawing and you want to delete a bunch of items at the same time. Is their a way to do it without clicking on each individual item with that d@mn little box with the eraser? Can I just make a box around it and delete all of it like in AutoCad? How? This is driving me nuts.
    Feb 2007
    414
    Re: Deleteing stuff
    Yes, use the Select icon from the drawing ops toolbar - it's the Arrow with Select beneath it, between the Query and Delete icons.
    Drag a box around the selection - only items fully inside the box with be selected - then press delete on the keyboard.
    Also, when you have selected some items, the cursor will change to a box with a plus/minus sign next to it. Use the cursor to select / deselect other items whether they are part of the original selection or not.
    You can also use the Edit > Delete All wizard from the top menus to delete many items at once.
    ATB
    Andre
  1. Replies: 0
    Last Post: 09-17-2014, 05:51 AM
  2. new at this cnc stuff
    By JAKE BISHOP in forum Community Club House
    Last Post: 05-08-2008, 05:47 PM
  3. Mach3 tuning (cuts small stuff fine, but is off on big stuff)
    By jdbaker in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 05:30 PM
  4. VF0 deleteing stored programs?
    By turboboy in forum Haas Mills
    Last Post: 08-10-2006, 03:07 AM
  5. welding thick stuff to thin stuff - need advice
    By cross6 in forum Welding Brazing Soldering Sealing
    Last Post: 01-13-2005, 08:39 AM
