586,051 active members*
3,644 visitors online*
Page 8 of 10 678910
Results 141 to 160 of 183
  1. #141
    Feb 2018
    20
    Re: New UC300ETH breakout board.
    Hi All... I just received a UB1/UC300ETH from CNCroom and I noticed it's a board revision 1.6 (dated 25/07/18 in handwriting on the board) but the manual online refers to PCB ver 1.5... I have had a general look and can't see anything different but wanted to make sure there was nothing I should be aware of. I'll check each pin for consistency as I connect of course - but can't hurt to check.
    Is there a revision history somewhere?
    Cheers - N
  2. #142
    35538
    You'll need to ask CNC Room.
  3. #143
    Nov 2006
    61
    Hi Talkiet,
    The circuit and components of UB1 board version 1.5 and 1.6 is 100% the same.
    But, there some improvements on bottom side of the board, some pads and vias are moved away from solder-bridge (SB). This prevents the excess solder bridges into nearby holes and vias. So, the users can solder the solder-bridge easily, without worry.
    I also put one extra square fiducial mark on the corner of v1.6 board. This helps to detect wrong direction feeding for pick and place machine in the production process.
    Thank you,
    Weerasak
    Weerasak.
    www.CNCRoom.com
  4. #144
    Feb 2018
    20
    Thankyou for the very quick response. I suspected it would be a non-functional improvement but thought it best to check. I'm about to start swapping out the UCNCv4 board now so wish me luck :-)
    I just got the license key as well (10 seconds ago!) so I am all set...
    Cheers - N
  5. #145
    Nov 2018
    14
  6. #146
    May 2009
    33
    What is a practical max step number for the uc300eth? I’m mostly interested in quieter operation of my machine. i have about a 5:1 ratio so at 800 steps per rev I have about 4000 steps per inch.
    Would the unit handle 1600 or 3200 steps per rev (for 16000 pulses per inch)?
  7. #147
    Jun 2015
    943
    Quote Originally Posted by vectorsc View Post
    The max.step number is not a property of the UC300ETH, it is a property of your stepper motor drive.
    The UC300ETH can do 400 000 steps per seconds per axis.
    Knowing the steps per value for your axis and the max.velocity you want you can calculate if the 400 000 Hz is enough or if it is not but usually stepper drives can't even handle 400 000 Hz frequencies and this means that the bottleneck is the stepper drive and not the UC300ETH, because it can output a higher frequency than what the stepper drive can handle.
  8. #148
    35538
    Yes, most stepper drives have a limit of 200Khz or less.
  9. #149
    May 2009
    33
    Thank you most helpful. My data says 200khz
  10. #150
    Jun 2015
    943
    Then the UC300ETH can run the most out of your drive.
  11. #151
    Nov 2006
    61
    Quote Originally Posted by Spinweight View Post
    Just got the UB1 board and need some help with setup please. I am not getting a variable voltage from the AO1 port.
    It needs a 10V into AH1 but my VFD only has 15V available so I'm using an external 12V power supply but all that I'm getting out of AO1 is what I put into AH1 and does not change with spindle speed.
    The K2 relay is working to start/stop the spindle with no speed control.
    I have set the Analog1 solder bridge to both the ANA1 and Y401 side with the same behavior at both.
    Any suggestions how I might get 0-10V out?
    First, You need to select either ANA1 or Y401. you can't select both at the same time. The default value is Y401.
    The LED status of AO1 will give a clue whether your configuration correct or not correct. On the UCCNC run screen, you need to enter and execute command "S10000 M3" in MDI (assumed 10000 is the maximum speed you gave in config>>axis setup>>spindle), then click the button[-] or [+] to override speed. At this point, you can see LED light dimmer or brighter depending on percentag of the override.
    If the LED status of AO1 stay on or off. this means that the software configuration is wrong. If this the case, please follow the UB1 instruction manual, page 24.
    You can use 15V from your VFD. The following instruction was given by ger21 and it appears on one of my product page.
    https://www.cncroom.com/interface-ca...-05-12v-module
    In UCCNC, the maximum voltage can be adjusted by changing the PWM max duty %. If you are seeing 11.8V at 100% PWM duty, reducing the max duty to 85% would give you approximately 10V.
    (11.8V x 0.85) = 10V
    Thank you for having my product in your hand.
    Weerasak.
    www.CNCRoom.com
  12. #152
    Nov 2018
    14
    Thank you for your priceless advice Vrasak. This problem seems impossible to diagnose without the help of experienced users.
    I have set the solder bridge to ANA1 and connected the 15v from the VFD to AO1.
    My setup was set with the UB1 UCCNC Profile from CNC room and matches every page of the manual.
    The voltage at A01 does not change with spindle speed. It will go up with spindle start but does not change with speed.
    When the wires are connected to the AO1, AH2 and AL2 the AO1 LED does not light up ever but AO2 stays on all the time although nothing is connected to AO2, AH2 or AL2.
    None of the behaviors change if I connect the wires to the #2 set.
  13. #153
    Nov 2006
    61
    From UB1 profile default setting. It will output PWM signal to both Y401 and Analog Ch2. So, you could get an analog signal from both AO1 and AO2.
    Here is PWM analog duplication. It also sends PWM to analog ch2. You can change it to ch1 as well.
    ***Please upload your UCCNC current profile so I can help you to tackle the problem.
    Weerasak.
    www.CNCRoom.com
  14. #154
    Nov 2018
    14
    The problem I had was in my wiring harness connection. Wired VFD directly to UB1 and it worked perfectly.
    Thank you for your help Weerasak.
  15. #155
    Oct 2016
    66
    Quote Originally Posted by Nickhofen View Post
    Hello everyone.
    Recently I purchase the UC300ETH-UB1 from cncroom, for a homemade cnc I build.
    I have 4 AM882,4 stepper motor 4nm each one, one 71volt psu I build.
    One 24volt psu , proximity switches NPN NC type.
    HY VFD with 2.2kw spindle and a 24 volt water pump.
    Soooo....
    I made this schematic and Weerasak from cncroom suggest me to post it here to get your opinion about the way I have connect everything.
    I am counting on your experience!
    Vfd is going to be connected according the second schematic.
    Any opinion and suggestion count!
    Thanks .
    Nick.
    Did your VFD worked with the wiring you provided? Is this how is supposed to be wired?
    I have the same BOB and looking for info on how to wire it.
  16. #156
    Oct 2016
    66
    Is this wiring correct for a Huanyang VFD to the UB1?
    AL2 TO ACM
    AO2 TO VI
    AH2 TO 10V
    NO1 TO FOR
    CM1 TO DCM
    X104 TO FA - SOLDER BRIDGE REQ'D
    GND TO FB
  17. #157
    35538
    I believe you want:
    AL1 TO ACM
    AO1 TO VI
    AH1 TO 10V
    with the PWM set to port 4 pin 1 (Y401).
    It appears that AL2-AO2-AH2 use the 2nd analog output channel on the UC300ETH. So if you use those, you need to set Spindle PWM > Analog Channel 2 in UCCNC.
    Not sure what you are using FA and FB for?
  18. #158
    Oct 2016
    66
    Thanks for your response, Gerry. FA and FB will be used to work with my E-stop which is currently wired to x103. By briging X103 and X104 under the board, when I press the e-stop the Spindle will stop? Thats the idea, would it work?
  19. #159
    35538
    Depends on how exactly you have everything wired.
    FA/FB can be configured to cause an estop.
    An Estop in UCCNC will stop the spindle by disabling the M3 relay output.
  20. #160
    Oct 2016
    66
    How can I configure Fa and Fb to cause an estop?
    Or what is the best method to wire an estop?
Page 8 of 10 678910
  1. Replies: 25
    Last Post: 12-13-2016, 08:44 PM
  2. Help deciding which breakout board or driver board etc to use!
    By localbroadcast in forum Servo Motors / Drives
    Last Post: 06-09-2016, 09:25 PM
  3. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  4. Breakout Board!!!???
    By Knucks in forum Stepper Motors / Drives
    Last Post: 03-25-2013, 10:12 AM
  5. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
