Problem with Z AXIS pin 6 and 7 motor only runs one direction. Swapped drives problem stayed the same. Took the terminal block off A axis and Z axis Drives . Swapped them now z axis will move in both directions A now only one way. So the direction pin is not working. I am to assume my break out board is bad? Software is set z axis pin 6 and 7 A axis 8 & 9 .The software shows a change in direction, in the dro when pressing jog buttons .The system is a smooth stepper feeding a c-10 break out board. The motion is very smooth and quiet. It fixed my p-port problem or driver issue. I am also having a problem with limit switch input. But that’s for later
