586,060 active members*
4,553 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Bridgeport Interact 412 - Loading G Code Help
Results 1 to 7 of 7
    I recently purchased a Bridgeport Interact 412 with a Fanuac controller. It has an RS-232 port for loading a program from an external source, but I am needing help in how to load a program from an external source (PC or jump drive)
    I currently have a CNC router that I have used for years, it is PC based and I use Mach 3 as a controller for it, so I am comfortable creating programs, loading and running them, but this new machining center is uncharted territory for me.
    As a frame of reference, I have the manuals for the machining center, have successfully had it home all three axis, but I have not been able to determine how to load code.
    Kevin
    May 2016
    526
    Re: Bridgeport Interact 412 - Loading G Code Help
    What fanuc controller does it have
    I'm not sure how to tell which controller it is. Is there a screen I can pull some information from?
    Here is a picre of the controller
    The Fanuc controller has a 25 pin D Shell connector on the side. I assume this is an RS-232 port. The previous company that owned this machine had an adapter going from the 25 pin connector to a CAT5 network cable and loaded G code from a network location, but could not tell me how to set it up.
    Any thoughts on what page on the Fanuc controller I can set it up to point to an external drive? I have poked around on different screens but nothing jumped out at me.
    Bump
    Aug 2017
    17
    My company makes a device called an Orion, that will hook up via RS-232 and will extend the memory of the machine also has a wifi adapter built into it to connect to your network....or you can use a flash drive that will plug directly into the Orion and upload your program from there. check it out online or PM me if you need more details. LINK Hardware
  1. Display off after loading g-code, z goes up to limit, new machine
    By Robot Dude in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2016, 02:07 AM
  2. Loading g-code from BobCAD
    By flyzoome in forum Mach Mill
    Last Post: 04-03-2012, 01:58 AM
  3. Mach3 - G code loading problem
    By rainnydayx in forum Mach Mill
    Last Post: 03-21-2011, 04:40 AM
  4. Bridgeport 1000/22 Loading Tools
    By BetaBob in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2010, 03:00 PM
  5. Bridgeport Series 1 Boss 5 PC file loading
    By Electricky in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2009, 03:51 PM
