586,121 active members*
3,249 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > ChinaCNCzone DSP CNC 6040 Router 4 Axis, 1500W /2200W Spindle questions
Results 1 to 3 of 3
    Apr 2017
    Hello,
    I'm looking at this CNC machine and would like to ask a few questions. I have read that lots of these come with hacked version of Mach 3. Can I use a bought version of the new Mach 4 with this machine.
    Also I'm trying to figure out if I can run this using USB and windows 10 or do I need to use something different or the SD card slot on the DSP controller? I would like to use this to cut small aluminum molds
    so I can test some seal designs. How was it getting this up and running smoothly and accurate? Also I'm not sure what a water sink cooling system is? Does this come with a water pump? Any other advice
    or comments you would be great.
    ChinaCNCzone DSP CNC 6040 Router 3 Axis 4 Axis with 1500W /2200W Spindle and Water Sink Cooling System Z axis 105mm
    Thank you for the help.
    Dave
    35538
    Re: ChinaCNCzone DSP CNC 6040 Router 4 Axis, 1500W /2200W Spindle questions
    If it's got a DSP control, than it's not using Mach3.
    To use it with Mach3/Mach4, or any other Windows control, you'll need a motion controller that's supported by the software you choose.
    "Water sink" is just a bad translation of water cooled spindle.
    Jul 2017
    Lightbulb Re: ChinaCNCzone DSP CNC 6040 Router 4 Axis, 1500W /2200W Spindle questions
    Hello Dave,
    After a long period of research, I finally ordered this machine [CNC 6040Z 4-Axis 1500W 80mm Water-cooling]. I received it today by TNT !
    Attachment 367140
    Attachment 367142
    At my request, ChinaCNCRouter made me a version with a USB controller for Mach4.
    Attachment 367144
    (This is the first machine they sell like this).
    They talk about it here:
    ChinaCNCzone Latest Mach4 CNC 6040 with Mach4 USB CNC Controller
    What are the New Features for Mach4 CNC Software?
    https://www.youtube.com/watch?v=4Hsvy4J9EJ8
    I have not tested yet. I have to prepare the place.
    Looking at it, it is a beautiful machine - solid construction.
    On the other hand, the spindle is cooled with water. A pump is provided, which also supplies a pipe for the cooling of the workpieces...
    Attachment 367146
    The "water sink" is a water recovery tank placed under the CNC.
    (I also took time to understand the difference).
    Attachment 367148
    I had various contacts (chat) with "Victoria" directly on the site.
    (She is therefore aware to provide a version for Mach4).
    China Mini CNC Routers, CNC Engraving Machine & CO2 Laser Engraving Machine Manufacturer Supplier. The service was very good.
    So much for the first information
    Guy-Laurent
  1. NEWBIE! 6040 Chinese Router Frame - Repeatability Questions & Build Review
    By LateNight72 in forum DIY CNC Router Table Machines
    Last Post: 08-05-2016, 10:54 PM
  2. Cheap 1500W Chinese spindle, experiences?
    By matth in forum DIY CNC Router Table Machines
    Last Post: 06-07-2016, 07:44 PM
  3. Replies: 1
    Last Post: 03-01-2016, 03:44 AM
  4. Getting a DIY CNC Router, 300W spindle or 1500W?
    By bonmotwang in forum DIY CNC Router Table Machines
    Last Post: 02-22-2011, 05:46 AM
