586,588 active members*
2,779 visitors online*
Results 1 to 6 of 6
    Oct 2011
    134
    Screw Tangs for MT2 or general MT Shank
    Hi All,
    Just hope someone can point me in the right direction i have a heap of MT2 Shanks for my lathe, the ones that don't have a flat tang have a thread that looks like it would accept some form of tang with a thread on the end. Can anyone point me in the direction of (a) what is the correct name and (b) where I could buy them from.
    Thanks in Advance,
    Adrian
    15362
    Re: Screw Tangs for MT2 or general MT Shank
    Quote Originally Posted by al010964 View Post
    Hi All,
    Thanks in Advance,
    Adrian
    Post a photo of what you have, it sounds like the are used with a draw bar
    Mactec54
    Oct 2011
    134
    Hi All,
    Found what I was looking for they are M10 screwable tang ... must be an odd ball item as I looked for hours and only found one site that has them.
    https://www.rc-machines.com/en/acces...tang-screwable
    Cheers,
    .adrian
    15362
    Hi All,
    Cheers,
    .adrian
    Good find, they would be an easy item to make
    Mactec54
    Oct 2011
    134
    Yes and was looking at going down that path, just wasn't sure if the would be heat treated and didn't have anything hard like SS on hand.
    But appreciate you taking the time to answer.
    Cheers,
    .adrian
    15362
    Cheers,
    .adrian
    A Drill Tang gets heat treated when the rest of the Drill is heat treated some are in the 60s RC some are no more than 48 RC, so if you made them out of something like 4140 that would do as is, the tang is only there so the drill Etc does not turn in the taper, the one's you have where used in milling machines with a drawbar, there is very little load on the tang if the taper is good
    Mactec54
  1. Replies: 5
    Last Post: 11-26-2014, 03:05 AM
  2. Replies: 2
    Last Post: 10-07-2011, 10:56 PM
  3. Pillow block and Screw and General Alignment
    By prestondocks in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2011, 11:14 PM
