Hello,
I need help for machining the surface from below pictures.
im also attaching the step file for part.
I was thinking on using an 16 mm diameter insert tool (high feeed mill cutter) and an 14 mm diameter with 0.5 mm radius corner end mill for wall finish
Many thanks
