586,231 active members*
3,120 visitors online*
Results 1 to 3 of 3
    Oct 2017
    3
    RFQ Aluminum Plate ATP-5 - 3D printer frame
    Hi Guys,
    I need some aluminum plate routed/cut etc. I will request a quote on one part of a 3d printer frame and the best quote will get the business for the full frame. Longer term I will need more stuff cut. The tighter the tolerances the better, but must not exceed +-0.01. I can supply the plate if required. The part step file is attached. Rough dimensions are 480mm x 70mm x 12.7. It would be good to establish a relationship with a service provider for prototype development longer term. I am very price sensitive.
    Hope to hear from you soon.
    Kind Regards,
    Peter
    Jul 2009
    85
    Re: RFQ Aluminum Plate ATP-5 - 3D printer frame
    .0004" of inch across 18" talking about some $$$
    Hi Peter,
    The price has been PM
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
  1. Looking for recommendations on License Plate Frame engraver
    By titkat in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2016, 01:42 PM
  2. Aluminum plate or extrusion for frame??
    By brutus_sp in forum Vertical Mill, Lathe Project Log
    Last Post: 02-19-2016, 05:32 PM
  3. Surfacing aluminum plate, for tooling plate
    By 30dayo in forum Material Machining Solutions
    Last Post: 12-21-2013, 11:29 PM
  4. Aluminum Extrusions, Steel, or Aluminum Tubing which one for CNC frame?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 06-14-2012, 02:51 AM
  5. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
