586,075 active members*
4,000 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Latest Fusion 360 Torch.cps post issues?
    Jun 2006
    8
    Is anyone else having issues with the latest Tormach.cps Fusion 360 post?
    The latest post version:
    post version 41493
    post modified 2017-07-01 154921
    Error I am receiving:
    Error(/Users/mfahey/Library/Application Support/Autodesk/Autodesk Fusion 360/WT6CL8W2YJPF/W.login/M/D2017012159758881/CAMPosts/tormach-pmf1.cps:1239): TypeError: gFeedModeModal is not a function
    Stack dump:
    onCircular@/Users/mfahey/Library/Application Support/Autodesk/Autodesk Fusion 360/WT6CL8W2YJPF/W.login/M/D2017012159758881/CAMPosts/tormach-pmf1.cps:1238
    Failed while processing onCircular() for record 281.
    Error: Failed to invoke function 'onCircular'.
    Error: Failed to invoke 'onCircular' in the post configuration.
    Error: Failed to execute configuration.
    Stop time: Thu Jul 13 18:57:00 2017
    Sep 2009
    1856
    Re: Latest Fusion 360 Torch.cps post issues?
    That is a blood hard bug to reproduces, It's something in the radius settings with G17 to 19 The HSM guys say not to use R for anything over 90 degrees
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Apr 2016
    109
    Quote Originally Posted by mikef137 View Post
    post version 41493
    Stack dump:
    Yes most all my posts are failing with that post processor. Had to go back to the last one. Same OnCircular errors.
    Jun 2006
    8
    I found what I believe to be the issue. It appears as though there is a syntax problem with some of the new inverse time code. I made the following changes:
    Search post file for: gFeedModeModal(94)
    Replace with: gFeedModeModal.format(94)
    Saved the post under a new name and add it to my directory and cloud library.
    Use this workaround at your own risk. I am not a programmer, nor have I tested the post and post changes for issues which could destroy parts, crash the mill, cause serious bodily harm or death, or bring an end to the universe....
    May 2015
    111
    There is an updated post available. It was in the forum yesterday and they are going to post it on the post site soon.
    It should be near the top of the forum
    Chris
    https://forums.autodesk.com/t5/hsm-p...a/td-p/7224183
  1. Mach 4 and ESS latest update issues
    By Prism_zet in forum Mach Software (ArtSoft software)
    Last Post: 08-14-2016, 04:53 AM
  2. Replies: 7
    Last Post: 06-23-2016, 02:50 PM
  3. Latest Path Pilot Post processor for Fusion 360.
    By LeeWay in forum Tormach PathPilot™
    Last Post: 03-31-2016, 08:24 PM
  4. latest plasma torch height controller (demo vedio)
    By larryy1022 in forum News Announcements
    Last Post: 06-19-2011, 01:33 PM
  5. Using latest torch on older model plasma cutter
    By Beefy in forum Hypertherm Plasma
    Last Post: 03-27-2011, 01:30 PM
