Originally Posted by
NIC 77
The bolt together design is more work to make, but way easier to move into tighter spaces, and to work on individual pieces, for example, when drilling the holes for your rails. The design I proposed has 16 bolts holding the bottom four pieces together. Torqued with lock washers, this would never move when assembled. You could bang on it all day long as hard as you can with a rubber mallet and never get it to shift. Sure, it would take a bit of alignment work if you take it apart and put it back together, but how often would that happen? Not really a problem IMO.
