586,104 active members*
3,371 visitors online*
    Dec 2010
    126
    Help with Spline profile generation
    Hello everyone,
    I am working on a shaft that has an internal spline cut into one side of it. We are requesting more information from the customer because I'm not sure if I even have enough information to make it. They supplied the following,
    25 Tooth Side Fit Straight
    Cylindrical Internal Involute Spline per JIS-B1603
    0.531 Major Diameter
    0.492 Minor Diameter
    0.500 Spline Length
    The spline has a relief to allow it to be broached appropriately. I need a way to generate the profile of the spline so I can model the part properly and get a single point broaching tool made. Is there enough information here, and can anyone help in generating a DXF or otherwise CAD-usable file of the profile? I looked around at a few different gear profile generators but they all seem to require a subscription or license, which does not make sense for one use.
    Let me know if anyone can help, thanks!
    May 2006
    803
    Re: Help with Spline profile generation
    Easy cad stuff .. need 24 decimal accuracy?
    no problem for a broach maker..........
    Show us the job, we are visual types.
    All this is inside the Machinery's Handbook. .
    They taught us gears from this in the 60's
    How many parts, what finished accuracy, material, hardness, ?
    This may get expensive for a correct, hardened cutter and precision indexing table
    Especially for a non-production one off.
    I don't have that broach laying around and have made them
    Involute curves are nautilus shell curves split open
    https://www.geartechnology.com/subje...c%20couplings/
    Been doing this too long
    Dec 2010
    126
    Easy for someone who deals with gears all day, I'm sure. That, I am not.
    We don't need any special accuracy.
    There is nothing to show, it is a hole in the end of a shaft with a spline callout, exactly as I have typed above.
    I've read through the machinery handbook but I'm not seeing where they define how to actually create a profile for a given spline. I'm also not clear on how to use the information I have been given to calculate the specifications needed to draw it accurately.
    The material will be 416 Stainless Steel in condition T (26 - 32 HRC). There will be 130 parts. We will be single-point broaching these on a CNC lathe, so no special equipment will be necessary other than the broach itself. We have done plenty of single point broaching, so that is not the issue.
    I don't need help with the application, I need help with the theory. I need a profile in order to make a broach, and a drawing for our internal inspection process. Is anyone able to shed some light on how to do this?
    Feb 2012
    41
  1. Help with Spline
    By jesuscowboy in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2012, 07:26 PM
  2. Sprocket Profile Generation
    By big_mak in forum Mechanical Calculations/Engineering Design
    Last Post: 08-17-2010, 01:25 AM
  3. Turning Spline profile
    By CNCinCal in forum Mastercam
    Last Post: 08-07-2010, 01:51 AM
  4. Take a look spline job
    By turboless in forum Employment Opportunity
    Last Post: 05-22-2009, 04:04 AM
  5. spline help,mc9.1
    By GRANDPA in forum Mastercam
    Last Post: 03-10-2007, 01:00 PM
