586,068 active members*
3,659 visitors online*
Results 1 to 3 of 3
    Feb 2011
    212
    Question Z axis Rapit after rest
    Hello I have an IH CNC mill that just started having an issue with Z axis. I started out as a z axis fault so I hit the reset on my machine. ( I have a reset button for each drive built into my control box ) So once I disengage the E ZStop button and reset each drive the Z axis wants to rapid to the moon. I have to press the E Stop button before it crashes into my limit switch.
    What could be the issue here?
    I have disconnected and reconnected the wires for all Z Axis to assure proper connection and still same thing,
    Any and all help would be greatly appreciated !
    May 2008
    1185
    Re: Z axis Rapit after rest
    Do you have the brushed DC servos or the Clear Path servos?
    If you have the older Gecko drive DC servos I bet you poped a driver. I have 5 extra here if you want a spare I can give you a good price. You could have lost a encoder but its less common.
    You can test the encoder by disconnecting the 70V line to the driver and power the drive +5V. If you rotate the servo and the lights give a yellow then red after a small amount of rotation then the encoder is working. Do it in both directions. If the encoder test good its the driver. Gecko has the test procedures at there site.
    Always a chance with brushed servos you have a burnt brush and armature.
    youtube videos of the G0704 under the name arizonavideo99
    Feb 2011
    212
    thanks for the input . I will swap out my 4th axis drive and see if that helps .TBH I am not sure if they have brushes or not. I can turn the power on with out mach 3 and as soon a I hit my reset button for the drive Z It just takes off
    Quote Originally Posted by arizonavideo View Post
  1. BOB has DIR,STP,GND,ENA driver has CP+,CP-,CW+,CW-,Rest-, Rest+.
    By bayouburner in forum CNC Machine Related Electronics
    Last Post: 06-15-2017, 03:27 PM
  2. 4th axis steady rest
    By Rachie in forum Want To Buy...Need help!
    Last Post: 02-14-2015, 08:23 AM
  3. Day of rest
    By cncadmin in forum EnRoute
    Last Post: 01-30-2012, 04:30 AM
  4. 4th axis steady rest
    By Autumn in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2010, 09:02 PM
  5. Would you use a z axis with lead screw if the rest of your rig use ballscrews?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 06-28-2010, 02:33 PM
