586,036 active members*
3,711 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Position following error on ACS806 + 57BL180D-1000 servo kit
    May 2015
    13
    Hello, some time ago I've bought an ACS806 servo drive and a 57BL180D-1000 servo from a chinese seller on Ebay, now I'm desperately trying to tune it using Leadshine's software "ProTuner" without any success.
    I've downloaded ProTuner directly from Leadshine's website, the version I'm using is the ACS806 v.2.0 according to the manual (the drive's serial number ends with MS22B).
    The problem is that I'm not able to lower the value of the position following error, it is always way too high, considering the manual, no matter what settings I change and if the speed reaches a certain value (527 RPM in my case) then it suddenly becomes unstable and the position following error increase drastically until the drive goes into alarm state.
    I'm using a regulated 36V 400W PSU to power the system, it should be similar to the Leadshine ones.
    What I'm doing wrong?
    Thanks, Matteo.
    May 2015
    13
    Re: Position following error on ACS806 + 57BL180D-1000 servo kit
    UP
    Inviato dal mio ASUS_Z00AD utilizzando Tapatalk
  1. Leadshine ACS806 AC servo ...smoked !
    By Larken in forum Leadshine
    Last Post: 08-15-2014, 03:31 AM
  2. tmc 1000 looses position.
    By barthmv in forum Benchtop Machines
    Last Post: 07-11-2012, 02:37 AM
  3. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  4. 414 servo error code Bridgepoint VMC 1000
    By drchris123 in forum Bridgeport / Hardinge Mills
    Last Post: 11-08-2010, 05:42 PM
