586,076 active members*
3,802 visitors online*
Results 1 to 7 of 7
    Oct 2010
    670
    Post for Fusion 360/PathPilot G54/G55/G56
    So, it looks like the post that Tormach has for F360/PP does not support multiple work offsets since it outputs G59 P54, G59 P55 and so on - which the controller coughs on when it loads (ver 1.9.11). Yes, I know I can manually go in and edit this but would rather adjust the post file to have it output whatever PP can support.
    Andrew Wall
    The Body Armor Dude - Andrew
    Oct 2010
    670
    Re: Post for Fusion 360/PathPilot G54/G55/G56
    From Tormach Customer Support:
    PathPilot does not support P54. It only supports G54-G59.3
    Looks like I'll need to get with Autodesk about a post adjustment.
    May 2015
    111
    Here is a post that works correctly. It was fixed on 5/26/2017 - Fixed G59.x output for Tormach PathPilot post.
    https://cam.autodesk.com/posts/downl...p?name=tormach
    Version 41497. It was just posted about an hour ago.
    Autodesk CAM | Post Library
    Chris
    Oct 2010
    670
    I must have something set wrong since cannot get any post to work that are dated in 2017. I'm using one from 2016 that works fine. Will have to dig into this a little deeper.
    Sep 2008
    325
    This is a little off topic but I was looking through the postprocessor text in the link and I noticed code for the Smart Cool nozzle that will change how it aims based on the type of machining operation. Has anyone seen those entries in their NC code?
    Jul 2016
    140
    Yes, but you have to enable smartcool in the post processor config screen.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    May 2016
    138
    If you havent figured it out yet and if it doesnt seem to be a problem with the post. When inputting the WCS Offset, you need to use Fusions numbering system
  1. Dolphin V13 - Tormach PathPilot Post Processor
    By drhardin in forum Dolphin CAD/CAM
    Last Post: 05-03-2017, 11:16 AM
  2. Mach3 to PathPilot what needs to change in my post and gcode?
    By thackman in forum Tormach PathPilot™
    Last Post: 08-26-2016, 04:34 PM
  3. PathPilot Preview Doesn't Match Fusion 360 Simulation
    By Spiffy Lab in forum Tormach PathPilot™
    Last Post: 08-09-2016, 09:15 PM
  4. CamWorks Post Processor for tormach pathpilot
    By ccsgtech in forum CamWorks
    Last Post: 01-25-2016, 08:43 PM
  5. Manual Tool Changes - PathPilot / Fusion 360
    By nickfabb in forum Tormach PathPilot™
    Last Post: 03-17-2015, 01:22 AM
