586,655 active members*
3,018 visitors online*
Results 1 to 6 of 6
    Jul 2005
    194
    Conversational Threading
    I am cutting some 1.25 x 20 threads in aluminum and while they work pretty well, it's not perfect and they come out rougher than I would like.
    It's easier with pictures so this is what I am up to. I am used to thread milling and I think I can do better here.
    Attached Thumbnails Attached Thumbnails 20170717_113719.jpg   20170717_113843.jpg   20170717_113857.jpg
    May 2008
    667
    Re: Conversational Threading
    There's some melted aluminum on the tip of the tool.
    It will not make a really good finish.
    Jeff
    Sep 2008
    325
    Quote Originally Posted by jeffrey001 View Post
    Jeff
    If you’re not already, try using coolant or lubricant such as WD40.
    Jul 2005
    194
    That's actually just a chip sitting there in a wrong spot, I should have brushed it away before I took the picture, the cutting edge looks exactly the same as the unused ones. I'm using flood coolant washing it pretty good the entire time. Im more curious about my recipe.
    Sep 2008
    325
    Quote Originally Posted by KSky View Post
    I don’t think it’s the problem but I would be using far fewer than 16 passes for a .040” deep thread in aluminum!
    May 2008
    667
    Quote Originally Posted by saabaero View Post
    That could be it, maybe the tool is just rubbing without cutting any material, I would cut in half the number of passes.
    Jeff
  1. G76 & Conversational Threading
    By rdsi in forum Tormach Slant Lathe
    Last Post: 01-30-2017, 12:14 AM
  2. Conversational G53 has no G0.. what's up with that???
    By SoCalPlaneDoc in forum Tormach PathPilot™
    Last Post: 08-25-2016, 08:52 PM
  3. THREADING: How to add threading parameters to the Init file?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-22-2015, 06:50 PM
  4. Replies: 10
    Last Post: 12-29-2008, 10:35 PM
