586,052 active members*
4,196 visitors online*
Results 1 to 6 of 6
    Aug 2016
    22
    MACH3 wont generate tool path
    Hello, MACH3 wont generate a toolpath. top right screen is light gray? restarted several times, it will ref all home fine, it will open and display the program, but hang up on generating toolpath. i also cant set my G54??? i can jog all over, re ref all home fine?????????help! thanks
    May 2012
    231
    Re: MACH3 wont generate tool path
    mach 3 is not cam program it only reads g code not produces it.
    Aug 2016
    22
    I produce G code either through Fusion360 or manually write it in notepad. My MACH3 software is not working as it always has and i don't know why. I suspect i need to un-install/re-install MACH3 which i beleive i need the internet for, however do not have Ethernet in the shop, so i'm hoping to find another solution. In my MACH3 setup, when a "Load G Code" command is initiated the file loads and it cut path is generated in the upper right screen. During loading a window momentarily opens indicating its gerearting the tool path, the same thing happen's when you press the REGEN TOOLPATH" . Mine now hangs up and never loads the program. Has anyone else encountered this and how did it get fixed? If a uninstall/re-install is required, is there a way to do it without the internet?
    Feb 2008
    482
    try under general settings tab- ignore macros when loading
    so much to learn, so much to pass on.
    Jul 2005
    2415
    MACH will not load "bad" code. See it the entire g-code loads and you can scroll to the end in the G-Code window. Use some code that loaded before. You may have the wrong POST selected in the CAM.
    Aug 2016
    22
    Hey all, thanks for the responces! I came across an old post that gave me the solution! while its hung up on generating the toolpath, press reset, then regen toolpath, and there it is!
  1. How to generate a Mach3 error when a drive gives a fault output
    By skillalot in forum Mach Wizards, Macros, & Addons
    Last Post: 02-20-2020, 04:02 AM
  2. Replies: 2
    Last Post: 01-07-2015, 10:54 AM
  3. Generate tool path for woodruff keyseat cutter to do undercuts
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-09-2014, 01:08 PM
  4. How to Generate a CNC code from measured 3D tool path
    By smar in forum OpenSource Software
    Last Post: 04-02-2009, 06:51 PM
