I have a new conversion for g0704 to 3 axis CNC with Kelling NEMA 23 steppers (570 oz-in, 5 A) for X and Y axis and NEMA 34 (906 oz-in) for Z.
I have installed AMT-102 encoders on the X and Y axis with 2048 counts (max). The Z axis is a US Digital encoder factory set to 5000 counts/rev.
I used the WiKi to perform initial sanity checks and tuning. System is operating in Encoder and Step_CL mode.
The issue:
When I move to Mach3, one axis suddenly jerks in jog mode and then triggers a disable. I then return to the Executive software, where same issue happens. Looking at the plots, it is obvious that the encoder is no longer working.
After removing power to Kflop, and re-powering, the encoder returns to a functional state (AMT 102 for x axis).
This seems to be an issue linked with communicating with Mach3 and not due to faulty wiring (at the moment).
I noticed that the hardware version is 4.33. I just bought the Kflop a few weeks ago. Is this a software bug that could be fixed with new a flash?
If this is a Mach3 setting error, I matched the tuning parameters from my initial exercise for V and A. V was adjusted to be units/min instead of units/sec.
I left the pin settings to be 0 0 0 0 (A A- B B-) under encoders for Mach3, no avail.
I disabled encoder in Mach3, that doesn't fix the problem.
Is this a pin/port setting mistake for encoders? I suspect the violent jerk and disable is caused by encoder not responding and then a fault is triggered.
Y axis occasionally does this behavior, but the issue is consistent with X.
Thank you!
