586,071 active members*
3,801 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Problems carving simple file- motor/driver issue?
    Jul 2017
    Question Problems carving simple file- motor/driver issue?
    Using a GShield and having bit of a weird carving issue. Tried sending file using GRBLcontrol, candle and Universal GCode Sender- all have the same issue.
    Heres my file loaded up in grblcontrol:
    2017-07-23 17.08.04.jpg2000x1125 401 KB
    Here's what it carves:
    2017-07-23 17.07.46.jpg2000x1125 251 KB
    Note the screwed up letter spacing and errors on the K
    Any ideas? I'm assuming one of the motors/something on the GShield is fried?
    Aug 2006
    44
    Re: Problems carving simple file- motor/driver issue?
    I think you are cutting with high speed.
    try to cut with very low feed rates
    Jun 2016
    28
    Looks like it's not directly connected with actual cutting but with rapid moves between cuts, it's possible that acceleration is set too high so steppers are stalling. But I assume that it's not your first try at milling so it's wise idea to think what has changed.
    Check your max feed rate when your code is issuing the g00 command it looks like your stalling out. Anytime G00 is issued it always uses your max feed rate.
    $110 Configuration x max rate, mm/min
    $111 Configuration y max rate, mm/min
    $112 Configuration z max rate, mm/min
  1. simple matching stepper motor to the driver
    By alihureiby in forum Maintenance DIY Discussion
    Last Post: 03-19-2017, 06:59 PM
  2. Replies: 9
    Last Post: 03-17-2015, 03:38 AM
  3. Stepper motor simple driver
    By Pysiek in forum Stepper Motors / Drives
    Last Post: 11-14-2014, 11:13 PM
  4. Need simple non-cnc stepper motor driver
    By BTD in forum Stepper Motors / Drives
    Last Post: 05-26-2010, 08:04 PM
  5. Mill file for SS simple 5804 PCB driver
    By pminmo in forum CNC Machine Related Electronics
    Last Post: 06-17-2004, 01:06 PM
