586,069 active members*
3,729 visitors online*
    Jul 2017
    8
    check out these pic's
    I am restoring a Taig CNC mill I am not sure on the age of the mill. I have found a few minor problems so far. 1. Z lead screw bearings were bad 2. the z nut was the old style. These parts are on order for replacement.
    I just removed the table and found some interesting patterns on the cross casting see pic’s some of it looks like the start of a center-less grinding pattern???
    Has anyone seen this before.
    Jun 2011
    68
    Re: check out these pic's
    The Criss-Cross pattern on the gibs are there for a reason.
    They are there to help retain lube!
    hth,
    Stuart
    Jul 2017
    8
    Quote Originally Posted by sclelectronics View Post
    hth,
    Stuart
    Hello
    I thought so and have seen it before.
    Rick
  1. CNC check
    By sml2010 in forum Uncategorised MetalWorking Machines
    Last Post: 10-18-2015, 05:04 PM
  2. Check out my 2nd cnc
    By bg_blea in forum DIY CNC Router Table Machines
    Last Post: 11-01-2012, 02:09 AM
  3. Replies: 5
    Last Post: 04-15-2011, 05:52 AM
  4. Can someone check this out!!!!!
    By macgemby in forum Commercial CNC Wood Routers
    Last Post: 10-09-2008, 06:10 AM
  5. Replies: 3
    Last Post: 01-19-2007, 02:59 PM
