586,076 active members*
4,012 visitors online*
    Feb 2006
    49
    hw allow Mach and Labview to drive a mill?
    Can somone suggest hw to allow either Mach or Labview to drive the same milling machine?
    I am planning a mill retrofit and want to drive the mill for metal
    cutting using Mach. I also have inspection needs for a big positioner
    to move a sensor over a part, so it would be nice to use the mill for
    that as well, but I want to drive it from Labview for that task so that
    the data logging from the sensor can be easily coordinated with
    motion.
    I thought I saw a post a while back about someone writing Labview VIs for the Gecko G-Rex, but I cannot find any confirmation of this now. I'm open to any hw to do this, so can you suggest any hw that will work with both software approaches.
    Thanks in advance,
    Doug Danielson
    Atlanta
    LabView should be able to drive the parallel port, so that would work for a parallel port based driver.
    -Jeff
    Feb 2006
    49
    I have not been able to find a Labview VI that sends the step and dir pulses out the parallel port. I hope I can find one rather than having to make my own.
    I thought I read in the past about someone writing a VI to drive the G-Rex from LV, but I have not found it yet.
    Thanks for your suggestion,
    Doug Danielson
    Feb 2005
    487
    do it the easy way,
    use your in a "Scanning" tool path, (create it in your cam as a surfacing operation with back and fourth raster moves).
    From Lab view once you up and ready to scan, press a button in the view that sends out a signal by what ever means, (i.e. modbus, or USB I/O, or what ever). In the Macro pump on mach have it running a If then statement, that when IsActive(INPUT1) or what ever comes on, then it does a DoOEMButton cycle start. Your scanning program starts running, and your inspection equipment starts putting in data into your Lab view app.
    scott
  1. RS 232 communication using LABview for modem
    By nabihahismail in forum Computers / Desktops / Networking
    Last Post: 09-28-2014, 05:38 PM
  2. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  3. VIs to allow Labview to drive the G-Rex?
    By wddanie in forum Gecko Drives
    Last Post: 03-11-2007, 08:08 PM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  5. will my drive work with mach 3
    By Fabric8r in forum Mach Mill
    Last Post: 02-01-2006, 12:46 PM
