586,069 active members*
3,402 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Operating CNC router at 25mtr/minute
Results 1 to 14 of 14
    Jun 2017
    21
    Hello There
    It took me 3month to build cnc router
    I am wondering where did missed
    My specs are as follows
    Working area:4*8 feet
    Actuation:TBI ball screws 3210 2510 and 1610 for xyz axis respectively And hiwin linear guide and bearing.
    Stepper motor: 1200oz-in (4.5 amp & 70v) and drive are of 6 amps 80v ac )
    Power supply: i have provided 80v and 6amp to each stepper /driver.
    I am running my cnc router 6mtr/m
    Successfully when drives is set on 6amp
    My stepper motor heats like hell
    When i reduce current my max speed also get reduced.
    Recently my friend showed broucher of some company.
    Company is claiming that max speed will be 25mtr/m that seriously gives me an anxiety. This is hard to believe where did i missed. Why i cant achieve this speed.
    And one more thing is that they are using rack and pinion.
    How this is possible.
    My steppers stalls whenever i try to go above 6mtr/m
    Sent from my Redmi Note 3 using Tapatalk
    Re: Operating CNC router at 25mtr/minute
    If you want 25m/min, you need to be using AC servo motors and ballscrews with 25-32mm pitch, or rack and pinion.
    You'll never be able to spin large stepper motors anywhere near as fast as you'd need.
    If you run 4.5A motors at 6 amps, the motors will not last long.
    Jun 2017
    21
    Thanks I agree with you
    But i guess giving current is not in out hand it is taken by motor(source).
    Is it like my motors will consume more current than it is rated?
    I am sure if it is so there will be problem.
    The motors don't control the current, the drives do. You need to set the drive current to match the motor's ratings.
    Jun 2017
    21
    I did same
    But it reduced my max speed by 2000mm/minute.
    Is there any way to make it more fast.
    Jun 2017
    21
    Quote Originally Posted by Junaidzia View Post
    I did same
    Is there any way to make it faster.
    Buy motor with a higher current rating, and drives that can provide a higher voltage.
    Get some 7 amp motors, and maybe drives like these:
    https://www.automationtechnologiesin...vers/kl-22083/
    But you still won't get anywhere near 25m/min. I think the best you could hope for would be 8-10m/min, but you may not even see that.
    If you want more speed, get some 3000 rpm 750w ac servos with a 2:1 belt reduction. That would give you 15m/min, if you don't have any issues spinning your screws at 1500rpm.
    Jun 2017
    21
    That means i only need to buy ac servo motors and drives.
    As you said i am already using reduction 1:2(timing belt and pulley)
    I am rotating nut.
    That cured my motor stalling and vibration problem.
    Jun 2017
    21
    Thank you very much
    It will help me a lot 😊
    God bless you
    Jul 2017
    18
    I am rotating nut.
    Would love to know more about these nuts !
    Thanks in advance
    Good evening
    Envoyé de mon A0001 en utilisant Tapatalk
    Jun 2017
    21
    Quote Originally Posted by silopolis View Post
    Thanks in advance
    Good evening
    Not special nut same nut used in rotating ball screw mechanisms.
    Jun 2017
    21
    Although​ there are ball nuts specially for that perpose
    Jul 2017
    18
    OK, thanks
    Jun 2017
    14
    What's the stepper motor you are using? It may because of your motor torque is too small. Try to replace a big torque motor. If your CNC router processing wood, 8000mm/min or 20000mm/min speed is normal
  1. operating a probotix cnc router using Mach 3
    By randyb47 in forum Mach Mill
    Last Post: 09-08-2016, 04:02 PM
  2. only take a minute.
    By Drools in forum CNC Machine Related Electronics
    Last Post: 01-02-2011, 08:37 PM
  3. acquired CNC router need help finding software and operating manuals
    By rsharitz in forum Education - Teachers and Students Hangout
    Last Post: 08-16-2010, 08:48 PM
  4. inches per minute
    By planescott in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2006, 01:29 AM
